Question about Palm LifeDrive Handheld
Lost calendar on hotsync
Okay, here is what happened: I set up to hotsync on my laptop for the first time. I failed to adjust the settings in the hotsync manager (I had lots of calendar info on the PDA that I wanted to put on the laptop), and all my info on the PDA got overwritten (although my few entries in my laptop's Outlook calendar never came over). I looked and I don't have a datebook.001.dat file, although my PDA says that all hotsync functions were successful. 1) How can I retrieve my calendar backup to restore the entries on my PDA? 2) I can't seem to open hotsync manager. I click, and it neither opens nor adds an icon to the task bar. Thanks!
  • 59 Answers
The information is unfortunately lost.
Unless you synced the palm on another computer, the palm only can back up the information when synced.
So if you sync it and the computer overwrites the handheld, the information never made it to the computer and thus cannot be restored.
The only thing you could check would be the backup folder in the palm directory under your profile name. Palm puts all of the .prc/.pdb files in there when you sync.
Posted on Jan 07, 2008
SOURCE:
I've completely lost my Calendar from my Palm ...
there is a option in your mobile ' set default' ok to it.
Apr 08, 2010 | Palm TX Handheld
Have a palm tx ,When calendar is chosen,the handheld crashes.
You probably need hard reset because there is most likely a corrupted program that is messing it up. I've gone through over ten different times where I had to hard reset. Get used to it.
Feb 12, 2010 | Palm TX Handheld
Lost all contacts, memos, tasks, after LifeDrive Update 1.0
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying, Handheld Tasks application database version not supported. Handheld Notes application database version not supported. Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC. I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem? thanks,
Sep 12, 2005 | Palm LifeDrive Handheld
Treo 650 is not syncing with outlook calendar, but syncing with everything else.
You may have tried Exchange ActiveSync in VersaMail When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo. So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
Sep 12, 2005 | Palm Treo 650 Handheld
Hot sync calendar from outlook to my palm
In my LifeDrive, my VersaMail set-up wasn't quite right. I had my e-mail address in as "name", rather than "name@mail.com". That fixed MY problem. Others (including me) are having trouble keeping the HotSync set to sync Calendar. It keeps going back to "Do Nothing" Go to HotSync in the system tray on your PC, right click, select Custom and see if your Calendar (conduit) is set to 'Do Nothing' as an action. I was able to get it to change and work, but just once (so far!!)
Sep 12, 2005 | Palm Zire 31 Handheld
Sync with Outlook
creat new calendar. Your msoutlook has a problem. Try this turn around. PC SETUP: ON MSOUTLOOK click on go to menu tap on FOLDER LIST to reveal the listing. On the outlook today tab right click and creat new folder - with calendar entries ON HOTSYNC BUTTON Go to Custom Highlight calendar tap on change tap on Settings On setting tap on browse then choose the new calendar you created. tap OK and set as default. then do a hotsync
T5 Outlook Calendar Synchronization failed - Any one have a fix?
I went to the MY COMPUTER folder, clicked open PROGRAM FILES, open PALMONE folder, open the username folder and deleted the back-up files. However, before I did this I deleted all of the problems dates in the PC calendar and set the hotsync to PC overrides handheld. While this works, unfortunately I have found that I need to do it every once in a while which is very disappointing. It seems that Windows does not operate seamlessly with the Palm T5. I find that the hotsync crashes 50% of the time forcing me to reset my Palm T5. No information is lost, but it is really a pain in the *** to have to do so often. Versamail hotsync sometimes freezes on the handheld, but that is another issue which I have managed to fix much in the same way as describe above.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
HotSync Outlook 2003 with Tungsten E
I tried all the suggestions that were offered and gave up. But then out of pure craziness I loaded the treo 600 CD that came with my Treo 600 out of curiosity. It loaded and the MS Office 2003 conduits loaded nicely and the problem appears to be solved for now. So I tested and it the Tungsten E Hotsync's feature all appear to be okay. I'm not sure if this is the best solution but it solved a very frustrating problem. The version of Hotsync that loaded is 4.1.0. Hope this helps.
Sep 11, 2005 | Palm Tungsten E Handheld
MS Outlook syncs calendar, notes but not contacts
Click on the hotsync icon in your system tray and then click "custom". That will bring up the list of things you are configured to sync with (conduits). For each of the ones you have problems with, click that conduit and then make sure it's set to sync the way you want...desktop overrides, handheld overrides, syncronize, etc. Potentially you have some of them selected as "do nothing". What shows up when I click custom from hotsync are the following Outlook Conduits: Calendar, Contacts, Tasks and Memos. If you don't have those showing up, you need to update your Outlook conduits on your PC. If you have them, click to select the problem conduit, then click "change" and select what you want to have happen.
Sep 11, 2005 | Palm m130 Handheld
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Sep 07, 2005 | Palm Treo 650 Handheld
Palm LifeDrive Handheld Logo
148 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
