Question about Linksys (WMP54GS) 802.11g/b Wireless Adapter
Blue screeen with error on RT2500USB for wusb54gv4
i got an old pc (celeron 2.0gb) from my dad, he was using wifi with the same adaptor without problem, i transferred the MB and chip into my old pc, hook up all hardwares and load a fresh copy of XP. But when i tried to connect the wifi adaptor, the pc could not detect it. Solved the detection problem with a PCI usb 2.0 adaptor. Then while trying to load the driver, it prompt me about no WHQL certification on my device, continued to load driver and the blue death screen appeared pointing to RT2500USB problem (driver).
If i boot the pc without hooking up the adaptor, it works fine which subsequently i can hook up the adaptor hoping it will work. And somtimes the adaptor works for a while and the conflict occurs again, if not an instant reset of pc will happen. I've spent many hours trying to troubleshoot but to no avail....Please help....
Is there a conflict of driver in this case?...I had tried it on a newer pc and it works fine. Linksys declared that it is not their adaptor problem.
awaiting for solution anxiously....Terence...(40+ hours spent)
  • de_peche2005 Sep 07, 2008
    You are my saviour!!!!...thank you so much SF. I got it working
    Scholar:
  • 141 Answers
Driver problem. Go into control panel and delete the adapter drivers. Remove the wifi adapter Then re-boot. I suspect the BSD (blue screen of death) was a result of a driver problem. If you have another computer that you can get on the internet with, go to the manufacturer website and download a driver. If you can get one, install the driver BEFORE plugging in the device and wait for the install program to prompt you to plug in the device. If you can't download a new driver, try plugging in the device again and see what happens. You need to avoid the BSD.
Posted on Sep 06, 2008
Where do I purchase an ethernet network adapter?
ebay and amazon. Get a usb version or one that goes inside if want wifi. Unless your PC is really really old every motherboard I've seen has a built in network adapter (rj45) looks like a big phone plug.
Feb 15, 2015 | Computers & Internet
Dell 520 not seeing the wifi circuit
Make sure the physical switch for the WiFi is on.
Nov 20, 2013 | Dell Latitude D520 - Celeron Intel Celeron...
I have a Belkin wireless g gaming adapter (ethernet) that i use with my pc ps3 and xbox360 i use late last night woke up this morning to no connection! every compute rin the house works just fine but this...
I have the same problem, one moment it works, the next, "No Connection" I use my Belkin adaptor with my Hi Fi to stream Internet radio. I have reset both the adaptor and my router twice without any luck. Check that your Dad has not changed the security settings on the router. If so, you will need to change the the adaptor settings to match. This adaptor does not have the strongest signal, so this also may need repositioning. Good luck. I am about to try re do the settings. failing this i have run out of ideas
Jan 06, 2011 | Belkin F5D7330 802.11g/b Wireless Adapter
LAN Adaptor not shown but wireless adaptor is activation how to enable Lan Adaptor
many latitudes are sold without wifi and/or bluetooth devices built in.
Bluetooth device is under the strip just beneath the screen (where power button is)
Open the lid on the backside of your computer on the left side (under tge 'A' button If you see just two loose cables and no board then you have no wifi in your laptop. !with missing boards the blue light is still switchable with Fn-F2!
Oct 03, 2010 | Dell Latitude D600 Notebook
Hi a philips x51 laptop help - almost dead apart from a few leds
Are you on battery mode?
If you are in battery mode, remove your laptop battery, plug in the adaptor to the laptop (without the battery) and plug to the power outlet. Turn on your laptop.
May 21, 2010 | Twinhead SlimNote N12PI Notebook PC
I am installing xp, I have a Celeron 478, I am having a blue screen IRQL_NOT_LESS_OR_EQUAL, what this means?
This means that your unit is having an error on one of the hardware installed on your PC, first thing to check is to change the memory module of your computer, this can be the first possible thing that you have a problem..
Hope this helps
Nov 23, 2009 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
My laptop screeen light seems dim without electricity
When you disconnect the power cord, the power settings change. Check the power settings for your screen backlight in Control-Panel-Power Settings.
Oct 14, 2009 | Samsung NC10-14GW PC Notebook
I was playing this game callled mu online then the LOS error came
Hi there Try and boot into safe mode and perform a system restore. To get it to boot in safe mode press F8 as the computer starts up, a sub menu will appear and use the cursor keys to scroll up, select safe mode and hit enter. If it lets you into safe mode use system restore to take the computer back a day or two, any data will not be lost. If you need anymore help or advice please post back. Good luck
Jun 04, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
The sims 2 exchange help?
Yes you will need to use your Dads account. Usually when you register an account you will need to type in the CD/DVD # code of your disk. This is that long number printed either on the back of the manual or sticked on the inside of the CD case. This number is then associated with the account you created.
Jun 04, 2009 | Microsoft 12.1" Touch Screen Terminal -...
Error loading operating system in dell
You may be right , the harddrive on the system may have gone bad.
You can run a diagnostics on the hardrive,shut down the computer, and then Press the Fn+ power button at the same time , it would initate the diagnostics.
Do post the results back
Thanks
proton
Apr 05, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Open Questions:
See all Linksys (WMP54GS) 802.11g/b Wireless Adapter Questions
Linksys (WMP54GS) 802.11g/b Wireless Adapter Logo
350 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
