83 Gold wing
The Honda Clarion cassette player is a model PH-890 I just need to know what the seven wires do Power ,ground left,right speaker etc. The bike has an itercom system and dont know if some of the wires are for that
Thanks
RD
    Brigadier General:
  • 3,614 Answers
Ok.. kindly wait
Posted on Sep 02, 2008
  • micromaster
    micromaster Sep 02, 2008
    1. RED is your constant voltage,
    2. the the YELLOW is your accessory
    voltage (used when you turn key this holds the memory in the deck.)
    3. the BLACK is the ground
    4. the BLUE and GREEN are the speaker.
    5. the WHITE is
    the ground for speakers as is the small black wire..
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
I have a 83 Honda Goldwing with a Clarion cassete player model # PH-890V There are seven wires that connect to the bikes wiring harness as follows blue, yellow,and green about 18 ga. Then there is a red...
the red is your constant voltage, the the yellow is your accessory voltage(used when you turn key this holds the memory in the deck. the black is the ground the blue and green are the speaker. the white is the ground for speakers as is the small black wire.. please rat this...thanks
Sep 02, 2008 | Audio Players & Recorders
I just installed a clarion type II am/fm/cb on my 83 golding. The handle bar switches work and the gauges work. But I get no sound what so ever. Before I put it all in the faring I tagged each set of...
Recheck the wires. If you do not plug everything into the right spots it will not work. Possibly one of the plug holes is mismarked. You may have to located the original instructions to get it hooked up correctly.
Aug 18, 2010 | 1980 Honda GL 1100 Innerstate Gold Wing
I HAVE A CLARION MODEL AB213R OUT OF AN IVECO
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
May 10, 2010 | Clarion ARX6670Z Cassette Player
Need wire colors power,ground,speakers/clarion arx6670zterryrose
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Oct 12, 2009 | Clarion ARX6670Z Cassette Player
I need to know what wiring harness i need for a clarion stereo model db365usb?
try this
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
purple right rear +
Sep 25, 2009 | Clarion DB365USB CD/MP3 Player w/USB
Wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Jun 25, 2009 | Clarion DXZ945MP CD Player
Lost the owners man, and need to hook up my Clarion VRX 485 VD
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
thats the radio here's the diagram for your car
1995 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Mar 18, 2009 | Clarion VRX485VD Car DVD Player
Clarion Model #PN-9881l plug wiring
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Jan 11, 2009 | Clarion XA-311 Cassette Player
Need to know what the seven wires are coming out of Clarion Cassette player model # PH-890v that came stock on a 83 GoldWing motorcycle. The wires are Blue Green Yellow (about 18 ga. (I know the blue is...
The blue one is switched because it has no power till you turn the key on This setup is on a Gold wing motorcycle with a intercom it is an elaborate setup The yellow wire shows a momentary grd every time you test it then nothing, no grd , no power
Sep 03, 2008 | Clarion Car Audio & Video
55 people viewed this question
 Grubhead
Grubhead
