Question about Brother DCP-110C All-In-One InkJet Printer
Brother DCP 110C has an error on the LCD screen it says unable to print...
Hi
I have the printer named above and I am having a really big problem, it keeps saying unable to print, I have checked that there is nothing stuck ie paper etc and there is nothing, I tried to turn it off and unplug so that it resets its self, but the error keeps coming up. Please can someone help me as I use this printer for work and I need to print out reports for clients.
Thanks
Michelle
Try reloading the software and check that the usb lead is connected inside the printer and to your computer.
Posted on Oct 04, 2008
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
My brother dcp 110c printer is unable to initiate and refers to routine maintenance - it does print out test sheets however and I have undertaken routine maintenance - not sure what else to do
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 48 - defective print head cable or circuit board.If the error is 46 the waste ink tank is full.Follow this:
1. Pres 'menu', 'mono start' then 'menu' one by one...
2. Press the arrow up or down to go to 'maintenance 80'.
3. Press 'mono start' several times to go to 'Purge'. Finding the PURGE will show some numeric value
which is Iassume the number of times the printer had cleaned.
4. Press 'arrow up' key and scroll for number "2" then press "set".Do the same for numbers 7, 8 and 3.
After you have entered this combination, the purge numeric value will be reset to 00000.
5.Restart printer
Nov 13, 2009 | Brother DCP-110C All-In-One InkJet Printer
Hi i have a brother printer 110c , the printer sayes unable to clean can you help solve the proplem thanks J
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the
error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
After you have entered this combination, the purge numeric value will be reseted to 00000.
Oct 27, 2009 | Brother DCP-110C All-In-One InkJet Printer
Hi, LCD displays unable to clean
From the printer's user guide:
Open the scanner cover and remove any foreign obstacles inside the DCP. If the error message continues, disconnect the DCP from
the power source for several minutes then reconnect it.
If still a problem, the printer has a mechanical problem and needs to be serviced.
Hope this helps.
Jul 07, 2009 | Brother DCP-110C All-In-One InkJet Printer
Print with my black cartridge ONLY
The only way is to set Grayscale Printing in the Printer Properties for DCP 110C.
I myself prints black only using this printer. Doing the above setting will minimize ( not prevent ) the usage of colour inks.
But take note that the colour ink will deplete itself matter of time.
Dec 29, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP 110C error unable to print
Hey, its the in-built annual maintenance by "Brother", get it to the service centre, if the warranty is valid. I've faced the same problem sometime last year, I'm facing it now. Which my warranty has already expired.
Sep 05, 2008 | Brother DCP-110C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
130 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
