Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Reply No leaks that are detectable, freezer at 0F refrigerator at 58F.
  • eugee1225 Sep 03, 2008
    The frezer works but the refridgerator section is at 87 degrees. I have tried everything. Clean and vacumed, played around with the controls and nothing.
    Brigadier General:
  • 3,614 Answers
You must check that there was no problem on the motor, and check also if there was still a freon on it...
let me know..
regards,
micro
Posted on Sep 02, 2008
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
My refrigerator rsg307 says on screen 0f 0f. what does that mean?
Of Of means it is in demo mode
Push energy saver and freezer button at the same time for 3 seconds....
Apr 21, 2013 | Samsung RSG307AARS Stainless Steel Side by...
Can't set the temp it blinks 0
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
Feb 04, 2013 | Refrigerators
On our Samsung RS267 and 25.5 cu ft refrigerator, we have an "OF" light on both temperature readouts (freezer and refrig.). What does this mean and how can the problem be rectify so that we will...
here is a video explaining (for all models) what is to do ..
http://www.samsung.com/us/support/owners/topic/RSG257AARS/XAA
Aug 15, 2011 | Refrigerators
My refrigerator is beeping and has high temperature both (freezer 30F and refrig. 58F). I try to set to default, but it didn't change.
your coils down at the bottom may be dirty & full of dust vacum it out. if the there is ice forming in the freezer it needs to be defrosted.
Oct 28, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Freezer -24 F and refigerator will not go below 58F
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Freezer is cold 0F and frige is warm 70F
cleaned it and door was open for a while. closed door and and an hour later alarm went off. alarm now flashing and alarm light still on. temperature now at 53. freezer 33
Feb 01, 2010 | Maytag MFI2568AE Side by Side French Door...
Freezer below temperature. Set to 0F and is at -20F.
If this is just a freezer then the likely problem is a failed thermostat. If it is a combo then check the refrigerator settings and possibly a door leak in the refrigerator. The refrigeration is shared between both sides and to my knowledge never 100% on either side.
Good Luck,
Gilsh
Nov 28, 2009 | Sub-Zero 601R
My Refrigerator is leaking a brown substance. Little at a time. Also leaking what appears to be water. Have cleaned coils. Also is there anyway to determine if refrigerator is accurately cold-like a...
Where is it leaking inside your refrigerator ? If it is inside your refrigerator at the back then it is likely a plugged defrost drain - there is a cup in your refrigerator that collects the water and sends it to the drain line at the back and at the bottom on your defrost pan for evaporation. if this line is clogged water will overflow and leak into your fridge. In newer refrigerators this line is enclosed and you have no cup in your refrigerator. See if you can locate the cup and wiggle it or remove it and push it back in sometimes it disloges the clog.
For temperature, normal freezer temp range is 0F or colder to 10F. Optimal is 0F (-18C), you can set it colder too this gives a better recovery time in case of longer power failures. For refrigerator 34F~40F, optimal temps are 34F, again for the same reasons, the colder it is, the slower bacteria growth - 34F is optimal, without freezing your food.
Aug 25, 2009 | Refrigerators
Refrigerator will not cool (58F) but freezer is working (-17F)?? Bottom mount freezer GE PDS22sc.
Check the back of the freezer if there is ice build up on the coils. If there is have the ice melted by unplugging the fridge. See if you can get the ice by just letting it melt on its own. The thermistor may have been frozen in the process and is not getting an accurate reading. Check also the freezer drain while at it and check if there is clogging. Other than that check the fan if you have one if it is running.
Jul 27, 2009 | GE Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
