Question about Sony Mavica MVC-FD71 Digital Camera
White Balance FD71
Can anyone tell me how to adjust white balance on this camera please? I can't find it in the instruction book but with the light I am using white comes out a sort of yellow. -- Brian K Tack
    Master:
  • 551 Answers
It's in the manual for sure. There are a couple of preset WB settings in the camera. You can access these by pressing the WB button on the lens, it will change the WB setting from one to another for every press. You can also do custom WB with one push botton.
Posted on Sep 13, 2005
Is it possible to turn off the white balance in a Sony Cybershot DSC H5?
White Balance is not a setting that can ever be turned off, it is simply your camera's way of telling what is white so that it can process colors correctly. You can however adjust the white balance manually or simply set it to auto. Auto white balance usually works great and I would highly recommend using it. To adjust your white balance, here are the steps:
1) Press the menu button. scroll using your arrow pad to the WB option and then press the Control Button.
2) This should bring up your white balance selection screen. Keep in mind that if your camera is in full auto ( the dial is set to the camera icon ) you will not be able to adjust your white balance.
I hope this helps!
May 05, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
My Canon G11 - most indoor pics have a strong yellow-orange hue. What can I do to correct this or is the camera broken?
Light from ordinary light bulbs has a strong yellow-orange cast, which our eyes tend to adjust for without thought. Check the white balance setting on your camera. This is to adjust the camera for the color of the light, to try to make white come out white, hence the name "white balance." Set the white balance to incandescent (light-bulb icon) for indoor shooting under light bulbs, or to automatic to let the camera take its best attempt.
Try experimenting with the white balance setting. Taking pictures in bright sunlight with the incandescent setting will give your pictures a very blue cast, making things look a little colder. There are other settings, such as flourescent.
Sep 19, 2010 | Cameras
White Balance
You can change the white balance in the "shooting menu".
Nov 11, 2009 | Cameras
White balance on D50 set correctly?
Are you saying that you're using a white background but it doesn't appear white in the pictures? If so, then yes, you need to change the white balance to match the light. Probably "tungsten" but you could try different settings and pick the one you like best or you could use a white piece of paper and set a manual white balance.
Oct 24, 2009 | Nikon D50 Digital Camera
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
The pictures are too blue.
It sounds like a White Balancing problem. I'd guess if it's set on Auto WB, then you'll need to do it manually. Some digital cameras tend to produce that blue tint when left to white balance themselves.
If you don't understand completely let us know the exact model of the camera and I'm sure somebody can talk you through it!
Oct 01, 2008 | Cameras
Canon EOS 400D
Gosh Megz, That's prolly more than anyone wants to type. Go to the Library or a book store. I'll try to explain white balance for you. Inside the camera is a program that evaluates the light during exposure. It tries to determine what is white and adjust the other colors in the photos accordingly by adjusting tint and temperature. Your eyes and brain do this for you. If you have a tripod try taking a photo in automatic mode and write down what the shutter speed and f stop was for that photo. Adjust your camera to those settings manually and take the same photo over. This way you will get a consistent photo to look at. Then change your color balance to different settings like daylight, cloudy, shade, tungsten (which is incandescent lighting) and fluorescent and view the difference in colors after you download to your image viewer on your computer. You'll think you went back to the late 60's.
Sep 13, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
White balance problem
There are two white balance adjustments in the Picture Menu. Check the user's manual and see which is best for you. Remember if you have "All Reset" set to Yes (Setup Menu). The white balance will reset to Auto each time you turn-on the camera. ............... XD media cards are the invention of Olympus and Fujifilm. Just their way of getting a piece of the pie. Just like Sony and the memory stick.
Sep 06, 2005 | Olympus Camedia C-765 Digital Camera
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
White Balance
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Sony Mavica MVC-FD71 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
