Question about Lexmark Office Equipment & Supplies
Printer will not put ink on paper. Ink are not empty
    Genius:
  • 2,985 Answers
More info on make of printer.
How do know ink not empty
What computer
What program in use
More more detail
Posted on Sep 02, 2008
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    My photo 924 printer will not print at all the paper comes out blank? What can I do?
    check the printer if it indicates that you have run out of ink? then an ink replacement is necessary, but if not, and printer is not giving any indication of ink replacement or if your ink cartridge still has ink try cleaning the printer head using the printer software installed in your computer try this 4 to 5 times if nothing happened then a hardware check up is needed to see what is the cause of the problem
    Nov 20, 2009 | Dell 924 All-in-One InkJet Printer
    I just put a new cartridge in my dell AIO 946 printer but it still says the ink level is low.
    well this always happens with all printers. I have a HP, in the beginning when I first bought the printer, it came with a ink cartridges, it showed the levels. But after the ink was all gone, it showed empty ink levels. The best way to solve this is to ignore this. When you see that your paper is poorly printer, then your ink cartridges need changing.
    Aug 28, 2009 | Dell 946 All-In-One InkJet Printer
    When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
    Here are all the flashing explanations:
    Two flashes: Out of paper or paper feed error
    Reload the paper correctly and press the RESUME/CANCEL button.
    Three flashes: Paper jam
    If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
    See Paper Jams
    Four flashes: Empty ink tank
    If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
    Refer to your Quick Start Guide for instructions on how to replace an ink tank.
    Five flashes: No print head installed/Defective print head
    Install the print head. Also, ensure that the protective tape has been removed.
    If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
    Eight flashes: Waste ink tank almost full
    The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
    Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
    Mp470 pixma
    Do you still need help with this problem?
    Regards,
    Worldvet
    Nov 01, 2008 | Canon PIXMA MP470 All-in-One Printer
    Canon S 520 doesn`t print
    Two flashes: Out of paper, paper jam or paper feed error
    Replace the paper correctly and press the RESUME/CANCEL button.
    If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
    button.
    If paper has jammed in the printer, clear the jam, replace the paper in the printer
    One of the ink tanks is empty. Replace it.
    Six flashes: No print head installed
    Install a print head.
    Seven flashes: Defective print head
    Remove and reinstall the print head.
    Also, ensure that the protective tape has been removed. If reinstalling the print head
    does not resolve the problem, replace it with a new one.
    becomes completely full, contact a Canon service representative to have the waste ink
    tank replaced. Canon recommends to call for service as soon as this error occurs. Once
    the waste ink tank becomes completely full, printing will be no longer
    possible.
    Oct 19, 2007 | Canon S520 InkJet Photo Printer
    21 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
