Question about Philips Magnavox 27MS343S 27" TV
Quick question: Magnavox TR2510
Can anyone tell me both the average wattage & the max wattage this TV uses? Thanks!
Quero entrar no menu de deserviço... Como faço???
Posted on Sep 06, 2008
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
N15232 motherboard wattage help
the power supply wattage rating is MAX wattage, not constant wattage. the power supply only outputs the amount of power that the rest of the computer calls for, and no more. if yor computer only needs 200 watts, that is all that will be sent from the power supply; even if it has a max rating of 600 watts, it will only send the amount of watts which your computer calls for.
May 08, 2010 | Computers & Internet
Need to upgrade Alienware PC with P5GD1-VM
You need 24 connection power supply 500 watt
Apr 29, 2010 | ASUS P5GD1-VM Motherboard
Hi i was just wondering if anyone could tell me what the max wattage is ?????
Hiya 50W RMS into 4 ohm per channel (X4) or 70Watt RMS into 2 ohm. The peak rating i think is about 150W
Jul 11, 2009 | Alpine MRV-F540 Car Audio Amplifier
How much generator do I need?
On average, a rooftop unit with pull 14 to 16 amps depending on the ambient temperature. I am not sure how big your microwave is but we will assume 1000W. The TV really doesn't pull that much. So, you have 16 amps at the Air Conditioner, 8.5 Amps at the Microwave and we will say 5 amps at the TV. Lets not forgot the converter for the coach which pulls 3 to 5 amps on average. Add all of these amps together and you have 34.5 on the high end. To get the size Wattage of generator needed to run 34.5 amps, you take 34.5 and multiple it by the electricity source, in your case 120V. That means that you have 4,140 Watts of power to be used max. I think that with a 4000 watt generator, you will be fine. You may be able to go a little bit smaller if your microwave is not that large. To find the amps of the microwave that you have, take the wattage and divide it by 120. That will give the average amps that it pulls while running.
Hope this helps,
Jul 04, 2009 | Coleman Mach 15 Air Conditioner
60" Philips Magnavox Projection TV Red Screen
be able to help more if you post model# and chassis.........meder's tv
May 19, 2009 | Philips Televison & Video
How many watts ?
maybe is 115 to 125 watts.but if want to see the true wattage of your unit ,look at back of your tv set then read the label the tv ,you'll find the true voltage and the wattage of your unit.
Jan 11, 2009 | Televison & Video
Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
TV demo mode
Press and hold the VOLUME UP and VOLUME DOWN keys simultaneously until the TV shuts off. Then turn it back on and you're ready to roll.
Jul 24, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
76 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
