I have a 83 Honda Goldwing with a Clarion cassete player model # PH-890V There are seven wires that connect to the bikes wiring harness as follows blue, yellow,and green about 18 ga. Then there is a red and white around 22 ga. Then there is a large and small black that are in the same harness then spilt at the connector I want to wire a standard radio CD player in its place. Thanks in advance for any help
  • Steve Aug 26, 2012
    I have a used unit if you are interested.
    President:
  • 1,263 Answers
The red is your constant voltage, the the yellow is your accessory voltage(used when you turn key this holds the memory in the deck. the black is the ground the blue and green are the speaker. the white is the ground for speakers as is the small black wire.. please rat this...thanks
Posted on Sep 02, 2008
    Brigadier General:
  • 3,614 Answers
May i know the exact model pf the cd player, i will find a wiring giagram for that
High Gregg my previous question About led panel going blank, My make and Model of bike is 1991 Honda Goldwing GL1500 Aspencade
Hi, Steve thanks for getting back to me I'm guessing due to the age of your bike it's probably a wiring issue the insulation gets brittle and starts to crack first thing I would do is check your instrument fuse if you have one next I would check the connection between the panel harness and the main wiring harness look for corroded, loose or broken pins. I found a free service and owners manual for you should have a wiring schematic in the electrical section for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GOLDWING GL1500 Owner Manual
Oct 11, 2016 | Honda Motorcycles
Can the Clarion NX500 fit perfectly in a 2010 Honda Pilot with a kit? If so, which kit(s)
Www.metraonline.com. simply choose your vehicle from the drop down menu and it gives you the parts you need. You need a kit and wiring harness. As for camera if your unit supports back up camera all you should need is the camera. It should have all wiring you need for it.
Jul 20, 2016 | Clarion NX500 Car Video Player
I need a wiring iagram for a 1980 clarion radio & CB for a honda goldwing can you help
clarion radio!!!!!!!!!!!!!!!!!!!!!
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
with the cb just connect the red and black wires upto the red and black on the radio then the cb wont switch on until u turn the accessories on
pls rate people arnt rating hope this helps
May 09, 2010 | Clarion DB245 CD Player
Where can I find a wiring harness for a head light on my 83 GL 1100 Goldwing
A very good machine look and see if it is under the seat or inside fairing if not try going online to honda and seeing if you can download or try googlin your machine and details re wiring harness for 83 gl 1100 remeber to keep the rubber down good luck
Dec 26, 2009 | 1983 Honda GL 1100 Gold Wing
Moter wont start on 83 goldwing batt new starter siniold new fues good makes a clinking new for siolnod
hav ur starter relay tested-its located by the batt-yhe bike is old-wires & parts deteriorate check plug cables n carbs ocasionaly
Dec 23, 2009 | 1983 Honda GL 1100 Gold Wing
Need to know what the seven wires are coming out of Clarion Cassette player model # PH-890v that came stock on a 83 GoldWing motorcycle. The wires are Blue Green Yellow (about 18 ga. (I know the blue is...
The blue one is switched because it has no power till you turn the key on This setup is on a Gold wing motorcycle with a intercom it is an elaborate setup The yellow wire shows a momentary grd every time you test it then nothing, no grd , no power
Sep 03, 2008 | Clarion Car Audio & Video
INSTALLING A CLARION MODEL DRX6375 CAR STEREO INTO MY HONDA ACCORD 1995
If you go to your local stereo shop (or even Wal-Mart..) you can get the harness that plugs directly into your cars wiring for about $5-10. It will have the EXACT same wire colors as the harness that came with the Clarion. Just match them up, plug it in and you're good to go!
Nov 09, 2007 | Clarion DRX6375
Car stereo wiring
http://www.clarion.com/us/en/MungoBlobs/752/342/VRX755VD-English.pdf
Sep 21, 2007 | Car Audio & Video
107 people viewed this question
 Grubhead
Grubhead
