Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Leaking inside of fridge
Is seems that there is an oil leak inside of my kenmore fridge. Is this possible. We've checked all the contents of the fridge and nothing seems to be leaking. Cleaned up the oil and it was back again in two days. The oil shows up under the vegetable crispers at the bottom of the fridge and is orange in colour.
Fridge and freezer seem to be cooling normally at the moment.
The fridge is about 3-5 years old, it's an upright with a top freezer.
Paul
  • 1,800 Answers
I guess u will benifit from this link
plz rate this post
click here
Posted on Sep 02, 2008
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Oct 17, 2009 | Kenmore Washing Machines
Water leaking from bottom of unit
Because the fridge by it's nature is classed as "Frost Free" it has a device called a condenser, this catches water into a tray at the back of the unit. Look inside the fridge and somewhere you will find a small drain hole, depending on make & model, it could be in several places, but this is probably blocked. Also check the tray at the rear of the appliance, this could also have a blocked drain in it.
May 01, 2009 | Kenmore Refrigerators
Leaky fridge
Can the water get out the normal way by that little defrostchannel hole in the back and down to the vaporizationplate on the compressor?. If not clean. If not possibly defrost totally because clogged witth ice already. takes longer then one hour .....
Apr 14, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
May 07, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
A leak from the fridge
Without knowing a bit more about the black fluid it is hard to guess where it could come from - in a fridge there should be no black fluid and the only oils are mixed in with the refrigerant so the fridge will not be working if any noticeable amount is leaking out, as the gas will leak out as well. As you mentioned, the most likely liquid is water from inside the fridge or condensation from inside or outside that has bacteria growing causing the blackness. this sort of water may usually only be in the water tray at the back but there are many possibilities of it leaking out somewhere else - only way to check is to get the fridge running, up on four chairs or a VERY strong glass table so you can see where it is comning from. Another possibility is that there is some insect, plant or rodent factor - the moist warm space under a fridge is quite popular and they can produce their own liquids and also especially rodents cause unpredictable holes and damage all over the place. also can only be checked by looking very closely at the source of the liquid. The last possible cause i can think of is some sort of corrosion - i have not heard of this type of corrosion with a fridge, but it is quite common on steel ships - salty humidity and chemicals (cleaners/cargo etc) reacting strangely with the paint or steel are normally blamed - just think if you get too many strong cleaning products near the bottom of the fridge and look for general condition of the paint/metal underneath you should be able to see it easily if the black fluid was in any significant quantity - there would usually be a sort of rusty look to the fluid, but not always depending on the combination of chemicals present. Where you describe the fluid coming from, sounds like it could be from the door insulation - maybe leaking through the bottom hinge holes - check that nothing is leaking into the door from inside, although condensation can easily happen in the door body itself if the insulation has separated slightly from the "skin" of the door inside. Last thing to try is to investigate the fluid itself a bit more closely - get some on a piece of kitchen paper towel or a coffee filter and then wet the paper with water also just next to the fluid- the parts of the liquid should separate out a little as the water soaks through the paper and you may just see something that looks familiar. If you get no luck post back and try to describe exactly what the fluid does smell like, without trying to imagine smells like "oil" which means nothing as they are all different and in particular fridge lubricants are relatively odourless. think of things you actually know the smell of and try and describe it in those terms - if you feel brave then it may be worth tasting the liquid - just taste a tiny tiny bit on a cotton bud/Q-tip dabbed on a few different areas of your tongue and then wash your mouth out with mouthwash straight after instead of spitting or swallowing - I know it sounds dangerous and disgusting but it is the way that many professionals identify unknown substances as taste has a much more specific "database" in the brain than smell has. just be sensible. Hope this helps - post back if not - photographs may help if you have a digital camera, especially of the coffee filter test if you get round to it :) Good luck
Jun 22, 2007 | Kenmore 64802 Top Freezer Refrigerator
Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Jan 15, 2007 | Frigidaire GLRS237ZA Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
398 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
