I need some info on repairing my BU-80 subwoofer. I can say this, the circuit board is one of the saddest soldering jobs I have ever seen. I found 5 cold solder joints!
-   making noise. unplug to stop. circuit board problem-   hammocks
Best Solution
posted on Aug 07, 2005
Powe33 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
E-Mail me, over 20 part references
Was this helpful?
Yes
No
Solution #2
Riddle - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
OK, but the BU-80 sold for about 129.00. Things won't change until people vote with their wallets.
Mark Z.
Was this helpful?
Yes
No
Solution #3
Reynolds - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
In a industry that has jumped on the computer model for built in obsolescence. Just why do you want a product built to last 20 years.
In 2 years it won't work with the latest and greatest anyway.
Roger
Was this helpful?
Yes
No
Solution #4
Horner - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Actually it is entirely reasonable to expect a subwoofer to last for more than a couple of years. It is compatible with virtually every audio system built in the last 40 years and will contiue to be so for years to come. The audio industry will only accept the model of obsolescence of the computer industry if consumers let them get away with building crap. Dealers and consumers need to bitch more.
Leonard Caillouet
Was this helpful?
Yes
No
Solution #5
Peter1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Well you need to take alook at a Zenith replacement board looks like a 5 yr old has done the job...
Most probably has.... Mexico.
kip -- "Watch the return E-Mail addy its false"
Was this helpful?
Yes
No
Solution #6
Gary10 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Your right Leonard, I don't service electronics any longer. I just don't have time, but I do help out friends when local so called Electronic Tech wanabees can't even see the obvious. I showed my friend his PCB, he knows nothing about electronics, and he found the problem! I have been in electronics since the age of 5, 25 years in the field and was involved even in the wave solding process. The BU-80 board had 5 broken solder joints. All the soldering on this PCB was the worse I have ever seen in high end grade electronics. Not one of the solder joints were thru solder joints! (Soldered thru both sides) Pretty sad for a piece of equipment that is going to vibrate. Lets try to forget about the underrated resistors that fry the board because of the way they are mounted!I understand many of Infinity's Sub Woofers have these same problems. Sad! And they want $20.00 dollars for the Service manual on a piece of shit designed speaker. I recomend against Infinity!
Was this helpful?
Yes
No
Solution #7
Charlie - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Do you service electronics? You must not if you think 5 bad solder joints is bad, or if you think you got them all. There are probably many more, as there are in most consumer electronics. I rarely service anything that I don't find at least a few suspect solder joints in that I resolder to prevent the inevitalble recalls for things that have nothing to do with the original problem.
I have two JBL Model L46 Speakers, about 25 years old. Foam on woofers has disintegrated. The...
(More)
I have two JBL Model L46 Speakers, about 25 years old. Foam on woofers has disintegrated. The Speaker Exchange in Tampa, FL, can repair for $ 44.00 each plus shipping. I have removed foam on one speaker and have removed 4 screws, but speaker will not come out (I have been gentle !). Can you advise next steps ? Thank You. Paul Cathcart ppcathcart@bellsouth.net
Yamaha HTR-6230 receiver.... connected cable box and my ps3 to the receiver with HDMIs only...
(More)
Yamaha HTR-6230 receiver.... connected cable box and my ps3 to the receiver with HDMIs only ....Problem 1 has no sound no picture while connected to cabel box ...Problem 2 has no sound connected to PS3 but has a picture.... SOS ppl
i have Bose home theatre speakers. There are 5. 3 don't work at all and 2 having a humming noise in...
(More)
i have Bose home theatre speakers. There are 5. 3 don't work at all and 2 having a humming noise in the background. Do you know how I can get it fixed? Thank you
Just recieved BU-80 speaker that needed some re-glueing, when I took the speaker out I found it was...
(More)
Just recieved BU-80 speaker that needed some re-glueing, when I took the speaker out I found it was not connected. Which wire is positive, blue or black
