Monitors
Problem for Monitors
Generic problem for all Monitors
Acer Monitor
By pssdeva on Sep 02, 2008
hello sir i have been using an acer al1916w monitor since an year now a days it shows grey shadows for everythng on my monitor it just adds shadows for everythng on my monitor though the shadows r very small but hurts when working on lng time.. i have checked my 3d card its fine...
Comments:
Sep 03, 2008
- Actually it happens with all the operating systems i ever used [XP , Vista Ultima , Linux Ubuntu 8] and those setting which you said just nw i have already tried them but it makes no difference... and about hardware i use an ATI X330 512mb card nd Acer AL1916W monitor using vga cable to connect to pc presently i am using WinXP... nd i have 1 more doubt do u think i can connect a ps2 or ps Video wires directly to my monitor using a SVGA to Video[Compac] wire.. ??
Clarification Request
Posted by Hanto on Sep 03, 2008
You failed to mention which O/S you are using, but I doubt you having a hardware issue as I've seen nothing on the internet that indicates the monitor might be causing this.
I think it's more likely that your settings/configuration is set to allowing shadowing of test and icons in your O/S which I don't like either but for some reason Microsoft and some of their customers seem to believe provide a better image. Being mostly a blind person myself I don't need Microsoft telling me what a good, distinct image looks like.
I'm using WinXP here so I will give you a quick walk-thru on locating the settings I have in mind that might be affecting your visual acuity. It's pretty much the same for Vista if you are using the newer O/S.
Locate Control Panel/System/Advanced/Performance ( Visual Effects )/Settings. There are 3 tabs there, with the first being Visual Effects. Default set by Microsoft allowing text and icon shadowing which actually only serves to slow your computer down. Instead of ' Adjust for Best Appearance ', set to ' Adjust for Best Performance '. Hit APPLY, then OK. This might take a couple of minutes to take hold as the screen will seem to go to a black and white mode while the re-configuration is taking place. Once it's done, reboot your computer for best chance that registry changes have taken place.
I'm hoping that is what you are talking about, however if it isn't, then come back with more exact information please.
By the way, I assume you know how to configure the monitor for brightness and contrast controls, because they can also be important in visual acuity of displays. For example I have a LCD monitor that functions as T.V. also, and I had it displaying a good t.v. picture but the VGA had to much blue tinge in it, which made it difficult for these old eyes to work with that monitor. I finally got into the monitor configuration and adjusted for best VGA display which ended up being a better display for T.V. also.
Like I said above, if above doesn't help, come back with more info please.
Best Solution
posted on Sep 03, 2008
Helpful)
Hanto
Rank: Guru
Rating: 88%, 245 votes
I have no idea about the game connection, don't add to many questions to this, as you can research that stuff yourself as you are now a expert in your own eyes. There is a driver for that monitor located on the Acer website and they offer a 3 year warrenty on the monitor. I doubt the driver will fix your issue, but it is at least worth a shot.
If what you say is true, then it looks like to me you've tried just about everything that can be tried and I would lean toward explaining to Acer why you need a replacement monitor.
Comments:
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
My monitor gets vertical bands of color and then starts to distort. If I use it a few minutes I can... (More)
Answer
i have aopen 19" flat...main connection that goes to computer at rear of monitor is loose and... (More)
Answer
I have a Viewsonic VX715 The issue with this particular unit is that the picture goes blank few... (More)
Answer
windows 7 support 1320X768 display? Display crad : intel G41 & LCD LG W1943sb
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
