Question about Acer Aspire 5610-4648 Notebook
PQSERVICE DID you ever manage to get your PQSERVICE onto a DVD+RW? I've just wiped mine
Does anyone knows where can i get an image (or ghost) of the primary Hard disk drive, including the hidden partition? My MBR and Wasay files are messed up and the best choice is to format C and image the origan back to it. But for that i will need the image of the original and not just a recovery disk.
Please help.
I know that acer technical department copy one disk to the other (incl the hidden)
Posted on Dec 05, 2009
I'm trying a backup of my Aspire One PQSERVICE to DVD after a near catastrophic partitioning experiment.
So far, I've booted from a Knoppix live CD and I'm trying partimage to copy the contents of the PQSERVICE to an image file on an external usb hard drive. Hopefully I can burn the image to DVD-R. So far, it looks promising.... even if I can't make a DVD-R from the image, I can use partimage to restore the PQSERVICE from the image file if I have to.
Another option would be to boot a knoppix live CD and just copy the contents of PQSERVICE to another disk or partition (not NTFS though). Linux doesn't care about the hidden drive partition settings that Windows uses.
Posted on Oct 07, 2008
I get error code Disc error 972. Is there an easy fix for this Regards Steve
From what I can tell, this error is caused when you've burned your own disc on a DVD+R/+RW. The Wii console only supports DVD-R/-RW. Check your media to see if you have DVD+R, and, if so, try burning onto a DVD-R (or DVD-RW, in case it doesn't work) and check it in your Wii again.
Jun 21, 2011 | Nintendo Wii Console
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I am trying to save an excel spreadsheet and QB's information onto a DVD+RW 4X int he "Open Writable CD folder using Windows Explorer but it will not copy. I see no other place to save it to
DVD-RW media has to be properly formatted to be able to write to it. Use a DVD management application like Roxio or Sonic. There are also some free apps online that can accomplish the same thing.
Apr 12, 2010 | Memorex (32025536) DVD-RW Storage Media
HL-DT-ST RW/DVD GCC-4243N wont burn dvds
Try uninstalling the Driver in Device Manager: in XP or earlier: Start/Control Panel/System/Hardware Tab/Device Manager, or in Vista & 7: Start/Control Panel/Device Manager.
Once in Device Manager click on the + sign that is in front of 'DVD/CD ROM drives' to open it up, then right click on the model of the Optical Drive in question.
Click Properties/Driver Tab/Uninstall (Advanced) & this will remove the driver if it is corrupt. Restart your system & the Hardware Manager will recognise the Optical Drive & install the necessary Driver.
If this doesn't solve your dillema then I hope that you have a warranty. Good luck in trying.
Kindest regards,
Ste
Apr 02, 2010 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
PQSERVICE hidden partition not found
depending on to what extent the last owner wiped the drive if they wiped the drive fully you will have to order the iso disks from acer they should be around 45 dollars for the set
Jul 17, 2009 | Computers & Internet
By mistake I bought a dvd rw disc instead of dvd-rw disc and recorded a holiday video on my camcorder with it. I usually then upload the contents of the dvd onto my hard drive (Pioneer) and then download...
Try uploading to your PC then converting it to AVI this keeps quality of video. Then if you want to download to a disk use Nero to convert it to VOB (DVD format) and burn off. You can also use Nero to erase the disk. (Nero 7 or more recent preferably.) You must also be sure you PC DVD read write head can take the DVD +/- RW. CHeck compatability.
Aug 12, 2008 | Computers & Internet
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
Will not record onto blank DVD's from HDD on LVW-5045 HDD-DVD 160 gb
Hi Barry - I too have a Lite-on and was initially over the moon with it. For the last year or so I have been unable to "read" disks and was just using it for the hard drive for recording - but this weekend my father in law had the exact same problem occur to his Lite-on and he bought a dvd cleaner (£5) - used it and it solved it - So I tried it and presto mine is reading and writing fine again - I was so chuffed - need to share this simple info just in case its a simple "dust" problem for anyone else that is having reading problems. DVD cleaner not just a CD cleaner as DVD cleaners have two brushes on it.
Jan 02, 2008 | Lite On LVW-5045 DVD Recorder
Can't burn movies onto dvd
in the software that u use to burn dvd...may be nero or roxio turn the dvd option on or select the dvd burning option.......u cannot use the xp writing sotware to burn dvds
Jan 01, 2008 | Pioneer DVR-112DSV DVD+RW Burner
Acer Aspire 5610-4648 Notebook Logo
1,337 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
