How do i find what an error code means?
Error code f-11 and f-28 what does it mean? Received the F11 code in 2006, they replaced both boards. I had purchased extended warranty. Seemed to work fine until a month ago, received dl (door lock) code, they replaced the door lock. Now I am getting the F11 code again after that repair. I do unplug the machine, wait a few hours and try to run the drain and spin cycle as suggested in manual. Sometimes it works and other times it does nothing. I then unplug and wait overnight. I am running again today, but I know it will stop again soon. I pray each time I start a load it will finish.
    Genius:
  • 1,028 Answers
If that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Posted on Sep 03, 2008
What does EE code on lg dryer mean
The EE error code stands for "EEprom Error" which means that the main control board EEprom program memory is defective.
Replace the main board.
Feb 19, 2015 | LG Washing Machines
What is an error code E5 mean?
Error code 5 means : Required temperature not reached.
Causes/Trubleshooting
Thermoblock has blown - replace thermoblock.
Power electronics is defective - replace the triacs of the power board or the whole power board.
Attention - determine resistance value of the Thermoblock to avoid subsequent errors.
Jul 09, 2013 | Jura Capresso Jura-Capresso J6
After cancelling auto clean I received an error code F14
"F1-4" error code means "Runaway temperature, lower oven".
The first thing I would do is check the lower oven temperature sensor. Pull the range out, remove the rear cover and locate the sensor wire harness to the control board. Measure the sensor resistance at the control board. Normally it suppose to be about 1100 Ohms at the room temperature. Also check the sensor wire harness and the sensor plug.
If the resistance reads wrong then replace the oven sensor.
If there is nothing wrong then the control board has to be replaced.Here is the sensor to order if it is bad.Here is the control board.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Maytag MER5775Q Electric Kitchen Range
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
What does it mean when you get a error code 5 when you are doing the magic focus?
Mean ur tv convergence board it is dead,any codes error at all,mean the tv convergence board have components it is dead and the board it just dosen't conververt it three CRTS tv colors Tubes like R,G,B colors lines yokes anymore.Now.The tv convergence board must have it parts replaced like 2 STK convergence ICS and some or all of it resistors too.After the tv fixed it convergence board,the tv will run the entire Magic Focus function,without any error codes at all.The tvs shops will cost u like $300-350 for parts and labors.
Jul 10, 2011 | Hitachi 53UWX10B 53" Rear Projection...
What does F1 mean for a whirlpool cabrio
F1 error code is for main board failure, replace main board
Sep 07, 2010 | Washing Machines
Received a service error 5C10, what do I need to do?
No 5C10 code to refer. I assume your error is 5010. If yes, that's mean your scanner unit is not functioning well. Need to replace it.
May 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
H5-01
Hello sir;That code means, fuser jam, fuser not installed or pcu main board/sub board, seem like fuser unit not installed.
Mar 22, 2009 | Sharp Office Equipment & Supplies
Washing Machines Logo
277 people viewed this question
Top Washing Machines Experts
