Question about Palm VIIx Handheld
Accidental hot sync with Outlook
When I loaded the Palm VIIx software onto my new computer from the website and did a hot sync, it somehow did a sync with the Microsoft Outlook (at least the calendar) and I am not sure how it happened but would like to know how I can do it again.
4 Suggested Answers
  • 473 Answers
SOURCE: Tungsten E and Outlook 2003 sync problem
I also have encountered this: The issues, however, started after our enterprise at work switched the backoffice server from Win2K pro to 2003 server. All users received new Outlook profiles. I know there are hidden services for Palm bundled into the outlook profile so I simply edited the old profile to point to the new server and proceeded as follows: CPU was an HP Pavilion DV1000 laptop with Windows XP Pro SP2 with Outlook 2003 to a Palm Tungsten E PDA. Unit would not synchronize contacts or calendar, producing "Calendar Synchronization Failed" and "Contacts Synchronization failed" errors. Creating entries in outlook contacts and calendar did not show up on the Palm. Creating entries on the PDA did not show up in Outlook. To rule out windows profile corruption, I backed up the users profile data, deleted her windows profile and logged back in to create a new one, copied all of her favorites, documents and desktop information back to the new profile and tried again. No joy. I created a new palm profile to rule out issues with the users original Palm profile being corrupt or damaged. I verified the hotsync app was pointing to the correct palm and outlook profiles. To rule out issues with her outlook profile being corrupt or damaged I backed up her contact and calendar data, wiped that too and created an all new one and re-imported the contact data from a personal folder not connected to an exchange server. No change. I deinstalled and reinstalled the Palm software as well as the conduits for outlook. No change. I downloaded the new and improved conduits that were supposed to fix issues with outlook synch problems. No change. I finally backed up all of the data on her palm by creating a new outlook profile that was not connected to our exchange server at the company but rather a personal folder on the PC and once the data was saved there the data was imported back to the users mailbox. This didn't work but it allowed us to back up all the data on the palm and let us perform some experimentation with formatting the palm clean as a plate and trying anew with her account and profiles - no change. I found the errors only occurred when logged in as the user herself. If I logged in as me and started fresh from a reinitialized palm on her computer it would work. Amazing. I even found that creating a new local user account on the PC and pointing at her own outlook account on the mail server wouldn't work either.. But it would work for my own. After some brainstorming.... I believe that the issue is related to a corrupt e-mail box on the actual mailserver itself rather than an issue with the workstation or the palm itself since if I log in as myself, I can set it up and make it work. I can use a different account. It works. But it ALWAYS fails when we attempt to attach to the users mailbox on the server itself. So, some of these issues could be related to changes or problems on an Outlook mailbox th
Posted on Sep 11, 2005
SOURCE: Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Posted on Oct 31, 2007
cropp
  • 377 Answers
SOURCE: Outlook Calendar synchronization failed in palm treo 650
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Posted on Mar 26, 2008
AvioriX
  • 689 Answers
SOURCE: New Computer, Palm M130 won't Hot Sync
Create a new Sync profile and check it again
Posted on Aug 24, 2009
0 characters
1 Points
Tx will no longer sync with outlook 2003 or outlook 2007 calendars. Software reinstalled, tx reset, latest updates for syncing with outlook 03 and outlook 07 loaded, still won't sync to outlook calendar...
I would recommend contact the palm free chat. Here is a link for that. I have a TX and have used the chat feature myself and always with good results. Scroll to the bottom of the page and then you will see Palm chat. From there click on chat now and follow the directions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/supportservices/page_en.html
Nov 18, 2009 | Palm TX Handheld
Cd doesnt install palm desktop software (palm z22)
You're saying you trying to install an appointment on your PDA. Has evrything worked before?
Dec 30, 2008 | Palm Z22 Handheld
Hot sync
Try reinstalling the Palm software from the CD into your computer. You should unistall it first and reinstall it.
Is this on a Windows Vista computer by any chance?
May 03, 2008 | Palm TX Handheld
Palm III sync program for outlook 2003
You can get a compatible palm desktop software and install it. it will let you sync again. you can get the palm desktop software from link below http://kb.palm.com/wps/portal/kb/common/article/33529_en.html
Sep 13, 2005 | Palm III
Tungsten E - HotSync with Outlook 2003
Don't skip the initial HotSync for secondary computer! Alright, I figured this one out on my own and figured I'd post what I'd learned so that others don't have to endure the teeth mashing, hair pulling, snarling frustration. (self induced as it may be) My experiences have taught me to not always trust a cookie cutter installation wizard...especially for custom app installations (ie: primary = home, secondary=work, total sync, no priority). So, I did not perform the initial sync during installation of the palm software fearing that the new installation would NOT recognize that the work computer was a secondary machine and resultantly wipe out the old palm data from the primary machine. Turns out, as I saw in many other unrelated posts, that it's difficult (if not impossible) to specify conduit direction to outlook 2003 outside of the initial sync (this prompted me to specifically look for conduit direction during install). So, this wizard is one I should have trusted...by mistake...because of weak program design. By the way...once I specified sync with outlook during the initial sync, EVERYTHING works fine despite not having installed the two "imperative" conduit updates (they were uninstalled after several previous failed attempts at this). Hope this helps
Sep 12, 2005 | Palm Tungsten E Handheld
Windows XP, Palm m130, & Outlook 2003 - Sync problem
It sounds like the computer is noticing the USB activity (from when you hit the HotSync button) but for some reason it can't find the correct information/driver. I'd first try a soft reset (stick a paper clip or the end of your stylus may screw off to reveal a pin, in the hole at the back of your palm) Don't worry, it won't delete your info UNLESS YOU HOLD DOWN THE POWER BUTTON (SO DON'T). Once it's booted back up, try the hotsync again. If that doesn't work, you may need to find the usb driver for your palm and reinstall it. This could just be copying a file from disc, or reloading your Palm Software. Good luck
Sep 12, 2005 | Palm m130 Handheld
Hot sync does not work
"PLEASE SET SYNCHRONIZATION OPTION ENABLE SYNC WHEN OUTLOOK IN UI IN ORDER TO SYNC IN OFFLINE MODE" Just go to your Hotsync Manager icon Click Custom Click each Outlook conduit ex. Calendar Outlook Click Change Click Settings Check the Box that says Enable Synchronization when Outlook is Offline Then do same process for Contacts, Tasks and Memos. Wherever your updated data is..make sure you set Action of conduit to example: Desktop Overwrites HH (if your OUTLOOK has the most updated data.) Hope that resolves your problem.
Sep 11, 2005 | Palm Zire 72 Handheld
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Sep 11, 2005 | Palm m130 Handheld
Palm VIIx Handheld Logo
21 people viewed this question
Top Palm PDAs Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Nataly Roberts
Nataly Roberts
Are you a Palm PDA Expert? Answer questions, earn points and help others
