Question about JVC AV-36150 36" TV
Hit by lighting
Lighting hit the house since the jvc av-36150 will not power on, can i try to fix this myself?. I am a handy person
thanks
  • stephysat Sep 02, 2008
    back is off set and the fuse is good the power cord is soldered to the board, is there a power supply module i can replace?
    thank you
    President:
  • 1,263 Answers
Chances are it fried the power supply module. you can get the part at a repair store mostimes the module just plugs in the main board, but it too could be a soldered connection........please rate this...
Posted on Sep 02, 2008
After a storm my tv nolonger turns on but the on
The TV has been spiked by a power surge. You could try to unplug it for several hours to see if it will reset. If this does not fix it then the problem is major, requring a new power board and possibly both sustain boards needing to be replaced. This is also very expensive about $600. If you have home insurance make a claim for FUSION. At least the parts will be paid for
Get the servbice person to actually write fusion damage on the receipt
Please rate my help++++Thanks for using FIXYA
Jun 12, 2010 | JVC AV-30W475 30" TV
I AM ON CABLE. MY JVC AV-36150 PICTURE IN FINE ON
You`re probably getting a on air channel which means that you have to check your cable connectors and splitter if you got any, switch with other sets if you can.
Nov 01, 2009 | JVC AV-36150 36" TV
JVC AV-32F702 Color TV shuts off after I power it on.
Any malfunction associated with a flashing light usually indicates a circuit problem or defective component. Unfortunately, the days of taking off the back cover of your TV and replacing a defective tube or fuse are long gone. Proper servicing will require troubleshooting procedures that can only be performed by a qualified electronic repair facility or professional television repair person. Ask for an estimate and a realistic appraisal of whether the set can be adequately fixed. Depending on the age and condition of your TV it may not be cost effective to repair.
Sep 12, 2009 | JVC AV-32F702 32" TV
Black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Jul 10, 2009 | JVC AV-36150 36" TV
JVC AV-32870 Power button is missing
I had a friend that had the exact same problem! We did use a remote to turn the tv on and then it was a matter of setting up the menu settings. It was trial and error, but it was worth it. As far as getting the power button replaced, I would recommend call and ask a TV repair person - but the remote worked just fine for my friend.
Jan 06, 2009 | JVC AV-32820 32" TV
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc av 36950 went off while watching, the same sound that you get when you turn set off. No sound, no picture, no red power light
This TV has a common problem. I've found dozens of owners with the same complaint. See the following blog for a simple fix for your set. I tried it and it worked and I spent under 2 bucks to fix it myself at home!
Good Luck......Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Dec 09, 2008 | JVC AV-36950 TV
JVC AV-27020 (110 volts) plugged into 220v outlet
Taking the tv to a local repair shop is probably much cheaper than having an engineer call at your house, though some self employed guys don't charge call-out. Try your local classified directory.
It might be as simple as a fuse. You should be able to check that for yourself or engage a handy neighbour. You should be able to download a manual from the manufacturer's website or just try a google search.
Whether it is a lost cause or not is not really predictable.
Oct 22, 2017 | JVC AV-27020 TV
29" crt tv video and sound problem
Is it possible that the input to the TV is still good including cables and cable box or anything? If another TV works from the same input then it may be the TV settings like AV/video rather than TV channels. Check all this out. I hope it is something simple as that. Good Luck.
Sep 22, 2008 | JVC AV-36150 36" TV
Power module
yes there should be a samll board that has the supply module on it it's the one with the direct link to the chord this board has a solid state module. if it doesn't on this model it should be the one on the main board that is directly linked to the small board.
Sep 02, 2008 | JVC AV-36150 36" TV
JVC AV-36150 36" TV Logo
59 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
