Question about Toshiba Satellite 1415-S173 Notebook
Not boot from factory CD -where is CMOS battery?
I went to format, reinstall Win XP and after formatting it stopped.  I have a new HD and still get error: Media test failure, check cable.  Operating system missing.  I suspect the CMOS battery but am not sure where it is, how to get to it.  My AC battery is also dead but I plug directly to AC outlet.  Haven't seen any direct answers to this model.  Thanks for any direction.
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
Based on your post/description:
  • Toshiba Satellite 1415-S173;
  • new HDD;
  • would install WinXP.
Your concerns are:
  • media/cable fault;
  • CMOS battery;
  • laptop battery.
  • will not complete format;
  • will not install OS (WinXP).
Proposed course of action and other ideas:
  1. double check the new HDD, verify that the pins are not bent and are seated correctly. If all else fails, return the new HDD and have it replaced;
  2. try partitioning/formatting the new HDD in another PC using a 2.5 IDE to USB external adapter;
  3. clean the lens of the DVD/CD ROM drive;
  4. remove the dead laptop battery and use only the AC power when installing;
  5. most current laptops do not use a CMOS battery;
  6. if you want to revert CMOS/BIOS settings to default, it could be done by pressing on ESC or F1 or as indicated in the display (depends on the version) and set all possible settings to default. Verify that it is set to boot from the CD drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
How can i reboot or format my hp laptop?
If you have recovery cd with your HP laptop just recover, coz HP laptop has recovery file in your hard disk to to recover to factory default. if no use bootable os like XP, VISTA and WIN 7are bootable just setup your bios setting, go to boot and setup your cd rom as your first boot so that it will automatically boot to your OS on the cd. and follow the rest of the instruction to setup.
Oct 07, 2010 | Computers & Internet
My sony vgn-fs515h crashed and when i went to restart it it now says no operating software found any ideas onn how to resolve this?
It may caused by the curreption(deletion) of important system files,
You can format and reinstall xp,vista,win 7,linux,mac os .
Restart computer when booting goes on press F5 Or DEL key to goto bios setup menu change boot order to first cd drive then hdd
PressF10 and press Y and enter.
computer will restart
Insert xp,vista,win 7,linux,mac os cd.
Press enter to boot from cd
Follow the instructions
Then your problem will solve.
Jul 28, 2010 | Sony VAIO VGN-FS515H Notebook
EMachines ET1810-01 trying to install xp pro on clean hd, cmos does not show hard drive and xp says there is no hd. it is connected. how do i get it to find the hd?
You need to format your hard drive. Set your boot device to cdrom in your bios. Boot using xp cd.DO a reinstall of windows and it should give you the option to format or delete partitions on your hard drive. if that doesnt work try putting the hard drive in another computer to see if it works. Or you can buy a hard drive enclosure that allows you to use your hard drive as an external device.
Jun 11, 2010 | eMachines (ET181001) (A1803181 ON) PC...
I installed a win 7 beta version on my pc..and when i wanted to revert it into vista again it won't install anymore to any os except win 7. When i tried to install vista it cannot detect my HDD, and when i...
To make sure you install back again your Windows Vista and Windows XP is this.
First:
  1. Go to Bios Setup and change the setting of your Hard Disk drive from Sata to IDE mode.
  2. Boot priority the CD/DVD Rom to run your Bootable CD/DVD.
This setting are quietly working, good luck!
Jul 29, 2009 | Computers & Internet
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Cmos cheksum bad
From your problem description, it sounds like a corrupt BIOS and or a failing motherboard.
Due to the system age, I'd say cut your losses, salvage what drives are usable, and get a new (or newer) system
Dec 07, 2008 | Computers & Internet
Hard disk
if you are installing a dos based system thn dos formatting is very good
if you are going to use xp then make boot option in setup as bootable from cd rom
put a win xp setup cd in the cdrom drive
it will boot up saying press any key to continue , and follow the scren instructions
the whole process is that simple a hd can be formatted till bad sectors are not shown up upto 8 %. more thna 8& bad sectors cannot load windows, however dos can still be loaded and so also win me so it doesnot affect the hd
what affects is the jerks and voltage supply variations on the har d disk and some bad virus infections and the temperature the hd has ... always leep hd at a tem p lower than 37 degres c
use a fan to achieve this a 12 volt small fan mounted on the hd .
Jul 29, 2008 | Computers & Internet
Shuttle mv43n v3.1
The problem is your motherboard itself. There is a short somewhere in it and is wreaking havoc on your attempts to get a system running.
I recommend getting your board exchanged if you're under warranty.
Please let me know if this helps. Good luck!
Mar 01, 2008 | Shuttle MV43N Motherboard
Not able to install win Xp
CHECK THE CMOS SETUP OF YOUR MOTHERBOARD,CHECK THE CMOS BATTERY AND MOST IMPORTANT READ YOUR MOTHERBOARD MANUAL INSTRUCTIONS
Feb 04, 2008 | Asrock M810LMR Motherboard
Toshiba Satellite 1415-S173 Notebook Logo
168 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
