Question about Memorex MVD2050-BLK DVD Player
MVD2050 remote control
I recently purchased a MVD2050 and all of a sudden the remote is not working. I replaced the battery, however, that was not the problem. Any thoughts?
  • 3 more comments
  • rsmith68 Dec 02, 2008
    I too have a remote MVD2050-BLK that has stopped working even with a new battery.
  • dj420000 Jan 03, 2009
    the MVD2050 BLK remote stopped working. I changed the battery. Still doesn't work. Please help?
  • Anonymous Feb 01, 2009
    The remote works, or at least sends a signal, and another remote that is trained to mimic this one also is not capable of controlling the dvd player. I think the player itself is the problem.
  • Anonymous Mar 02, 2009
    battery operated remote does not work even after replacing battery. what is the problem?
  • YoMartin Apr 04, 2009
    My remote went out. I replaced the battery. No joy. I even had the battery thoroughly tested by my electronics friend. Battery good. I did the video camera trick and there is light coming out of the remote. Then I tried it on the player and it works sometimes. When it fails, I think I'll have to remove power from the unit for 30 secs. If that doesn't work, time to get a new player. Dang! and I bought that TV Guardian thing too.
If you point the remote at a video camera and press any button on the remote while the camera is recording you should see the emitter flashing on playback. This will confirm that the remote has indeed failed or working. I did this and found the remote working... Now on to the player.
Posted on Dec 03, 2008
2001 ml320, remotes quit working. new batteries,
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment
Jan 09, 2010 | 2002 Mercedes-Benz C-Class
Suddenly stopped working, green light on remote works, but no response from car. No locks, trunk, or start.
Could be many things, loose ground or power wire on the 561, there is an inline power fuse on the red wire leading to the control unit that may be blown. It may just need to have the remotes reprogrammed to the control unit, sometimes the control unit just stops recognizing the remotes. If you have recently had the cars battery replaced, or jump started the car, check the fuse at the control unit first.
Aug 17, 2009 | Directed Dei Valet 561r Remote...
Wii remote works with normal batteries but not with battery pack
same poblem if this is solved cud somwon plz send me the solution to jordanchattington@hotmail.com cheers
Jun 30, 2009 | Nintendo Wii Remote Controller
Our remote control for our tv suddenly stopped working
There are three possible causes; here are the solutions for each:
  1. The batteries are dead. They need to be replaced.
  2. The remote has developed a defect. The remote needs to be replaced with the same one from the manufacture or a suitable Universal remote from your local retailer.
  3. The IR receiver in the TV itself has developed a defect. This would require the TV being repaired by a qualified technician who would purchase the circuit board from a parts distributor. You would be responsible for parts and labor if the TV isn't in warranty.
No, the remote can't be repaired if it's now defective. It can only be replaced.
Feb 03, 2009 | Motorola DRC450 Remote Control
My MVD2050 has a usb slot amount other things... but i dont know how to get the slot the show the information in the flash drive. Can you help me
you plug in ur usb and on your remote bottom right i think you push the A/B button to switch from dvd to other source
Jan 10, 2009 | Memorex MVD2050-BLK DVD Player
Memorex MVD2050 problem with buttons on machine
Hi..
No offense but Memorex is junk.
Get you money back and try walmart or someone else
Dec 26, 2008 | Memorex MVD2050-BLK DVD Player
Memorex MVD2050-BLK DVD Player Logo
340 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
