Question about Acer AL1916W 19" LCD Monitor
Grey Shadows for everythng on monitor
Hi i have been using my acer al1916w since an year and now i find grey coloured shadowns for everythng on my monitor every image and every thing i have checked my 3d card its fine with other monitor... hope i get a solution here...
  • 12 Answers
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Posted on Feb 07, 2010
We have had this monitor for about a year and it just started flickering with dark colours. How can we fix it?
If it is less than one year, then contact ACER, and exercise the "warranty" to get it repaired/replaced at _minimal_ cost to you.
Mar 06, 2011 | Acer AL1916W 19" LCD Monitor
I bought an LCD Monitor Model AL1916W,Acer. It was working good and for my job it was excellent.However, yesterday without any other problem the screen went to white.Power button went red.I closed and open...
christidis d, If AL1916W has white screen when connected to a "known-good" pc, then the units "switch-mode-power-supply" has gone bad. Most monitors have +5 volts and +12volts dc to power up the electronics. +12v for the inverter circuit which lights-up the 2 cold cathode fluorescent lamps, and +5v for the vga to lcd panel digital signal processing board. One or both of dc rails may be out of regulation and or a bit "noisey" due to failed "electrolytic filter capacitors" on the SMPS board. Let me know the brand name of the capacitors you find on the SMPS board. What is the "date of manufacture" on rear of monitor?
12fixlouie
Sep 08, 2010 | Acer AL1916W 19" LCD Monitor
Hi there can you help with my HP2605? Since i replace a blue cartridge (a compatibal one. We have been using compatible cartridges for over year and so far so good.)3 weeks ago the printing is not week....
click on the alignment button and have the machine automatically start the realignment process
it is not color realignment but printer head alignment that is the problem
May 04, 2017 | HP LaserJet 2605dn Printer
Grey bands and shadowing
Uninstall the video driver from the Computer, restart the Computer then reinstall it. Furthermore, check for any updates for the video drivers.
You may also connect the monitor to any other normally functioning Computer to check if the lines remain there.
If it's so then the monitor requires servicing.
Nov 07, 2009 | Samsung SyncMaster 244T Monitor
I get "No Signal" shortly after the computer is turned.
there is a problem by the programming chip insifde of monitor. It can be faster fixed but only by an expert. If i've help you, please rate me! Thanks
Sep 15, 2009 | Acer AL1916W 19" LCD Monitor
Floating box
erm......reduce your graphic card output.
Sep 09, 2009 | Acer AL1916W 19" LCD Monitor
Black screen after a year of use
Sine a flashlight on the screen and check for a dim image. If you see a dim image the back light needs to be replaced. After doing that you will want to try using another monitor cable and see if that helps. If it doesn't with the computer on and the monitor on disconnect the cable from the computer. If the monitor shows a no signal error the graphics card needs to be replaced.
Sep 07, 2009 | Acer AL1916W 19" LCD Monitor
Acer Monitor
I have no idea about the game connection, don't add to many questions to this, as you can research that stuff yourself as you are now a expert in your own eyes. There is a driver for that monitor located on the Acer website and they offer a 3 year warrenty on the monitor. I doubt the driver will fix your issue, but it is at least worth a shot.
If what you say is true, then it looks like to me you've tried just about everything that can be tried and I would lean toward explaining to Acer why you need a replacement monitor.
Sep 02, 2008 | Computers & Internet
Acer AL1916W 19" LCD Monitor Logo
489 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
