Question about LG WM1814CW Front Load Washer
I am having the same problem as you stated with you WM1814CW
Did you ever get it repaired or back running? Should I order the drain pump and install it myself? Is it simple?
Thanks
Mike (mikemaciasUH@sbcglobal.net)
  • 489 Answers
Replacing the drain pump is not that hard. But you will need to confirm that is the problem.  Remove the filter drain plug to make sure there is no large build up of debris blocking the filter.
Posted on Sep 29, 2008
How do I put hose back in behind lower cover cap? pulled completely out when attempting to drain hose & clean the pump filter.
Go to www.youtube.com and enter
LG WM1814CW
Into search bar on youtube.
You will see various videos on How To Fix your exact model washing machine. :) x
Nov 17, 2014 | LG WM1814CW Front Load Washer
Wm1814cw le error cade
Make sure your drain hose is not bent - the code looks like a drain issue. It could be your drain pump. I had to take mine off and it was full of "gunk" and that can keep it from draining, causing that code. I have no affiliation with Home Depot, but they have a great web site showing how to get to the drain pump and how to take it off and clean it or probably just to replace it. Go in to the area to order the part and there should be an option to view a video on how to install it - not too hard, just follow directions. www.homedepot.com/ApplianceRepair 48de78f6-d540-4f0d-8488-f3f5c589abed.jpg 1bc73971-d1f5-473d-8b8f-f05840bc9002.jpg
Jul 16, 2014 | LG WM1814CW Front Load Washer
Problem with LG WM1814CW Front Load Washer. It has stopped with water inside and it says OE. I have checked the back pipe, but with water inside, can i open filter
The OE error is telling you the water hasn't drained out in ten minutes. To fix I would first start with cleaning the filter on the pump. If that doesn't fix i would recommend replacing the pump. I would also have towels and a mop in hand because when you unscrew the filter top the water that is inside the tub will come out. You should try leaning washer back before removing filter to prevent the mess.If you have to replace the pump they run about 50 or 60 bucks. I hope this helps.
Oct 27, 2012 | LG WM1814CW Front Load Washer
Our LG Tromm WM1814CW frontload washer is not draining in the spin cycle, but its only sometimes. We have tried cleaning the Filter and its clear, we looked in where the filter is to see if its clogged,...
hi Shellinator7.
check the small drain hose on the side of the pump that is clogged, then that is not a failure that will significantly affect the normal operation of the washer. If your washer is not draining okay and you don't mind catching some water that spills out of that pump filter area when you open it up, then you don't necessarily need to remove that front panel and bother with unclogging that small drain hose. If the large hose between the tub and the pump or the discharge hose between the pump and the house drain behind the washer is clogged, then you may need to open up that cabinet.
you could also check out this link and read up some more on this.
LG Tromm front load washer not draining in the spin cycle Google Search
Dec 14, 2017 | LG WM1814CW Front Load Washer
De comes on the front and wont drain wm1814cw
the machine is clogged is th hose kinked,try to push the start buton again,you should hear the pump come on and try to drain.when it stops,push the button again,when the door unlocks take cloths out.And put 1/2c of bleach in drum and let it soak a few hrs.Now start washer no clothes this may do it,after cycle put clothes back in and run clothes through full cycle.When ther done.Put in Draino-Drain opener gell only and let it set over nite,then run heavy duty cycle this well clean washes and clean pump.
Jul 26, 2010 | LG WM1814CW Front Load Washer
I have an error message on my LG WM1814CW washer The message
This means the machine did not drain within a 10 minute time period. check the pump trap for debris and clean out. Check the drian hose. Check for drain pump operation diring drain period
Mar 06, 2009 | LG WM1814CW Front Load Washer
LG1814WM will not drain properly
Start checking the drain lines at the back of machine, ensure that the drain hose is not blocked.
If this does not fix the problem , then access the drain pump, and check the drain hose and pump are not blocked.
If still no luck, you need to have the pump and valve solenoid tested by a technician , to ensure valve it is not stuck or faulty, by energizing the solenoid.
If the pump solenoid is fine, and pump opens and close, then the problem is usually the control panel, rarely can also be a contact on wiring harness to the pump.
Eneter model number here to find parts and diagrams for your appliance.
Here also parts and repair help.
Mar 04, 2009 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
319 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
