Question about Linare Desktop, AMD Sempron 2200,40 GB HDD & 128 MB RAM
Windows HP AMD Vista PC won't awaken from sleep/hibernate - sometimes
I've had my vista home premium PC for one yr + and its sometimes won't awaken from sleep/hibernate ( usually overnite ) .Sometimes it does, other times NO and I have to pwr down and remove pwr plug, wait one minute. It reboots, usually says windows shut down unexpectedly. I'm up to date with video & windows updates including SP1. No change to intermittent waking problem.checked with HP support. de;leted screensaver. no change Looked at event viewer, but not sure what I'm looking at. Is there a software conflict? How can I diagnose this. Vista should fix this ??? Should I buy a registry/error tool, like REcure. HELP
CHUCK
  • jes0458 Oct 04, 2008
    I have vista home premium as well. When I choose shutdown, the blue power light never goes off. it appears to go to sleep but won't awaken. Then I have to hold the power button down and have to power off. Upon re start I get " the computer did not shut down properly
To the original poster: There's a patch from HP related to this. Visit hp.com, and review the support download and drivers.
Below is the solution if you can't find the patch from HP, or if you're one of the countless people having this problem on another brand computer (usually an Acer or Toshiba with Vista and AMD chips).
The problem is actually related to the screen-saver, not to sleep/suspend/hibernate, although since they tend to happen in similar time frames and similar ways, it's hard to pinpoint. To resolve...
1. Set your computer power-scheme to "max performance" or "high performance".
1a. Alternatively, go to Power Settings, then click on Change Plan Settings, then click on Change Advanced Power Settings, Scroll down to Processor Power Management, and set Minimum Processor State to 100 percent for both plugged in and battery.
(For 1 and 1a, I realize some people don't like that the "solution" is actually a "work-around", but at this point in time, nobody from either Microsoft or AMD has fully "fixed" the problem, so to use your computer, you're stuck with a lowly "avoid the problem" workaround.)
2. You have AMD chips in your computer, so chances are, you have ATI powered video. Go to Catalyst Control Center, and turn off "PowerPlay".
3. Also for your power settings, set your "Turn off monitor" setting to a suitable value, 5 to 20 minutes (whatever your like), AND TURN OFF THE SCREENSAVER ENTIRELY. The "turn off monitor" will do basically the same things that the screen saver would do, and avoids the problem that Vista/AMD computers sometimes have.
If you're brave, you can skep step 3, but I recommend doing all 3 of the steps.
Posted on Jan 12, 2009
Vista will not sleep
I may try, but first please answer these questions:
1. Which program are you trying to put Vista with to sleep?
2. Do you have a laptop or a desktop PC?
Of course I will reply, I always do.
Feb 24, 2013 | Microsoft Windows Vista Home Premium with...
Tip
How to disable and re-enable hibernation on a computer that is running Windows
The Hiberfil.sys hidden system file is located in the root folder of the drive where the operating system is installed. The Windows Kernel Power Manager reserves this file when you install Microsoft Windows. The size of this file is approximately equal to the amount of random access memory (RAM) that is installed on the computer.
The computer uses the Hiberfil.sys file to store a copy of the system memory on the hard disk when the hybrid sleep setting is turned on. If this file is not present, the computer cannot hibernate.
Hibernation is made unavailable when you set the value of the Hibernate after setting to Never by using the Power Options item in Control Panel. To make hibernation unavailable, follow these steps:
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt, and then click Run as Administrator.
When you are prompted by User Account Control, click Continue.
At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
Type exit, and then press ENTER.
To make hibernation available, follow these steps:
At the command prompt, type powercfg.exe /hibernate on, and then press ENTER.
Type exit, and then press ENTER to close the Command Prompt window.
APPLIES TO
Windows Vista Business
Windows Vista Enterprise
Windows Vista Home Basic
Windows Vista Starter
Windows Vista Ultimate
Windows Server 2008 Datacenter without Hyper-V
Windows Server 2008 Enterprise without Hyper-V
Windows Server 2008 for Itanium-Based Systems
Windows Server 2008 Standard without Hyper-V
Windows Web Server 2008
Windows Server 2008 R2 Datacenter
Windows Server 2008 R2 Enterprise
Windows Server 2008 R2 Standard
Windows 7 Enterprise
Windows 7 Enterprise N
Windows 7 Professional
Windows 7 Professional N
Windows 7 Ultimate
Windows 7 Ultimate N
http://support.microsoft.com/kb/920730
on Nov 19, 2013 | Microsoft Windows Vista Home Premium with...
Tip
Issue with hybrid sleep feature and hibernation feature in Windows Vista
The hybrid sleep feature and the hibernation feature in Windows Vista may become unavailable after you use the Disk Cleanup Tool SYMPTOMS
To resolve this problem in Windows Vista, run the powercfg -h on command at a command prompt to enable the hibernate feature and the hybrid sleep feature.
To run this command, follow these steps:
1. Click Start , click All Programs , and then click Accessories .
2. Right-click Command Prompt , and then click Run as administrator . If you are prompted for an administrator password or for confirmation, type the password, or click Continue .
Type powercfg -h on, and then press ENTER.
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
Acer 1916
Go into control panel, power options, go to hibernate, "top right" and click. Uncheck hibernate box, next! power schemes, " top left " and click, go down lelt side, "system standby " select never from the list and close window. This will prevent your laptop going to sleep, shutdown windows when you are finished.
Apr 23, 2012 | Acer Computers & Internet
Hp officejet j3640 not working on windows vista. I had the printer working and when disconnected when moved it doesn't work. I've tried uninstalling and reinstalling the driver several times....
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
Oct 29, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
I have an emachines El-1352G-41W What are my options to expand this system into "CAD" system?
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
  • Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
  • For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
  • 2 GB free disk space for installation
  • 1,024 x 768 display resolution with true color
  • Microsoft® Internet Explorer® 7.0 or later
  • Install from download or DVD
Jul 11, 2011 | Acer eMachines Black EL1352G-41w Desktop...
How can I enable hibernation on my HP Mini 5101?
Welcome to FixYa, the world's largest product support community.
Generally all Windows OS has an option for sleep & hibernate.
Windows XP Users
  • Sleep Mode
By letting your computer idle for a period of time, i.e. not moving the mouse/touchpad, or not pressing any keys except when playing a video, the screen or desktop monitor will go dark. You can resume the computer by moving the mouse/touchpad or by pressing any key on the keyboard.
  • Hibernation or Standby mode
Click Start, click on Turn Off Computer, then click Stand By.
Windows VISTA/Windows 7 Users
To put Windows VISTA & Windows 7 in Sleep or in Hibernation, the steps basically the same. First click Start, then click the small arrow head located to the right of the Start Menu, then you click Sleep or Hibernate.
Fig. 1. Windows VISTA Start Menu. To put Windows VISTA to Sleep or Hibernate, click the small arrow head right next the Lock icon then click Sleep or Hibernate.
Fig. 2. Windows 7 Start Menu.
To put Windows 7 to Sleep or Hibernate, click the small arrow head right next the word Shut Down then click Sleep or Hibernate.
Jun 09, 2011 | HEWLETT-PACKARD HP Mini 5101 Netbook
Sleep mode does not work properly
go to control panel power ption thern clik on hibernate
and enabvle check box of hibernation so it start from where u end
May 24, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My hp 530 laptop with windows vista doesn't sleep or hibernate
Sleep/hibernate is a function of the video driver. so download and install the latest video driver from hp.com
Dec 13, 2008 | Computers & Internet
AMD Turion vs Intel Pentium processor
No there are no issues with Vista and the processor of the computer.
Jun 22, 2008 | Computers & Internet
Computers & Internet Logo
344 people viewed this question
Top Linare Computers & Internet Experts
gautam jha
Level 1 Expert
Carlos L. Burgos
Carlos L. Burgos
Iqbal Husain
Iqbal Husain
Are you a Linare Computer and Internet Expert? Answer questions, earn points and help others
