Question about Miele Washing Machines
Miele W 404 plus - just over 5 years old. Started getting various inlet and outlet LEDs flashing - but confirmed they are all clear. Won't drain properly - now getting drain/ finish LED flashing ... Any ideas please ?
  • mccartt Sep 02, 2008
    The filter was badly blocked with grey residue which seems to have built up very quickly over a reasonably short period of time. Note my wife normally checks this regularly and we have not had this problem before.
    We haven't changed powder or anything of late.
    I have checked all inlets and they are fine. Inlet water pressure is good.
    As I said the outlet filter was quite blocked so I cleaned all that and also flushed through all the outlet lines etc, which although had some residue were not too bad.
    Nothing else has changed as far as I am aware.
    I am just wondering if there is a micro switch or something that has become contaminated or something along those lines.
    Any thoughts much appreciated ...
    President:
  • 1,462 Answers
Have you checked filter? and check for foreign object in pump while you are about it
Posted on Sep 02, 2008
  • douglas smith Sep 03, 2008
    another thought
    is machine plumbed in to a spigot on the sink trap? if so, check the spigot itself as this can become blocked by debris from the sink.
    also, to check the pump itself is ok, put water in machine and power the pump direct from mains and see if the flow from the pump is then good.
Miele G641 SC Plus Drain /inlet light 4 short 1 long flash. How do I find a fault code chart?
Inlet / Drain is a general fault meaning there was no water movement when it was necessary to start the pump. Either it didn\'t drain out or it didn\'t fill the last time.
Call 800-999-1360 for free Miele tech support. They will advise you free of charge. You will perform step by step control board operations over the phone to clear the fault code as well as advise you how to cleanout the drain pump.
Dec 27, 2014 | Miele Dishwashers
Have miele dishwasher g641 inlet/outlet light flashing the water is going in and is draining starts flashing about 5/10 mins after starting do you know what else to try many thanks janet
Just encountered exact same problem - happened after attempting to clean very greasy pans so grease/oil created foam/more or less solid material in filter area, but as well in pressure switch (pn 4859640)
This seems to be the cause (not sure yet)
Mar 07, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Hi My dishwasher Miele G692 SC has the inlet/drain light illuminated. I have cleared the inlet and tap connection..... Any other suggestions before I ring Miele?
Have you checked the drain? On mine a small piece of broken glass had got past all the filters and had blocked the paddles of the pump - you have to release the spring clip and take off the top of the pump housing. Miele's seem very fussy about any blockages to the water outlet system.
You then have to hold down the start button to force a restart (cost me a call out to learn that) - but it is stated, sort of, in the problem fixing manual.
Nov 01, 2010 | Miele Dishwashers
Inlet/outlet light keeps flashing on G641 dishwasher - have checked filter and cleared debris. Just completed a wash but dishes not washed or rinsed adequately. Anything else I can check before requesting...
hi,
this is a general fault light which could mean anything without a Miele Technician coming out and connecting a
laptop to the unit. However most common faults with dishwashers is a drain fault. Check for any kinked hoses and check the drain spigot under the sink where the drain hose connects into the u bend. Usually this is where food gets trapped due to the spigot not being drilled out large enough. This then causes a blockage. Also check the non return valve under the filter and make sure the drain pump can turn freely. See what part of the cycle the unit lights up the fault. If it happens at the very start it is the drain. If it drains ok then fails it is the inlet. If it fails after that it could be any number of things.
Hope this helps.
Jan 26, 2010 | Miele 24 in. Novotronic G641 Plus Built-In...
Red light flashes when it gets to rinse cycle
complain to miele be a pain they have given discounts on a new one before. try running apple cyder vinager through it pore some in let it run a little then open the door and let it soak for a day or so and then try it again it may just be dirty good luck
Dec 08, 2009 | Miele 23 in. Novotronic G841 Built-In...
Outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Sep 22, 2009 | Miele Dishwashers
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Washing Machines Logo
248 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
