Question about GE Energy Star WCVH6260F Front Load Washer
Model: WBVH5200J2WW Three weeks ago, my washer spilled water all around and under. Upon initial investigating I have discover a 2X2 inch rip in the gray booth seal. It took GE a full week to replace it. I have to mention terrible Customer Service, which we had to call more than four times... Several days after corrective action I've encountered same problem with flood in the laundry room, only difference is, the rip is about 8 inch long, (when looking into the door opening between 7 and 12 O'clock position). That's it for me, I will ask for my money back and going to by a good old Maytag. GE should stick with building Jet engines and bulbs and not washers any more... This is a cronic and serious issue. Our washer and drier have been purchased in March of 2008, still under warranty. Dan Plavsic
  • jgbalb Dec 18, 2008
    My laundry room keeps getting flooded but only when I do a load of towels. I have cut my load size by more than half and it still happens. I don't have any tears or rips in the gray seal.
  • Anonymous May 17, 2009
    torn gasket
  • 725 Answers
Call for service it is cover under warranty... all front loaders have a door gasket and all of them get holes in them...
Posted on Nov 17, 2008
  • jlp1782 Dec 28, 2010
    What is the part number of the seal?
Replace door gasket on GE wbvh5200j2ww
First of all, obtain a replacement gasket, then disassemble the door sufficiently to allow installation of the new gasket
Mar 23, 2013 | GE Washing Machines
Cant get washer to pump out the water
Water pump Is shot can be fixed parts labor not cheap better to get new washer then it comes warranty sorry
Feb 21, 2013 | Washing Machines
GE washer model#WBVH5200J2WW wash machine will not pump out water, will fill but will not pump out- any suggestions would be Great
Pump is toast can be fixed at repair shop or tech guy but usually better off with new washer parts labor not cheap chance happen again likely
Feb 21, 2013 | GE WSXH208A Front Load Washer
My mom's washer, while washing suddenly heard a loud bang and water just started coming out of the washer. what happened? She does'nt know but has not used her washer for 2 weeks.
Could be leak from pump or hose gone under machine spilling water on to Electrics.Also could be heating element, you need to investigate further
Mar 30, 2010 | Washing Machines
Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Apr 23, 2009 | Karcher 2500 PSI Pressure Washer
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
Frigidaire front load Gallerry series washer model GLTF2070DS0
HI thanks for your question. repair clinic on line . part# or model # and they ship in 3 days good you can fix your self. thanks
Oct 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GWH9100LW1 Frontloader problem
Found the tip on another thread of this site. Remove the 3 star screws located below the access panel that's below the door and clean the trap/filter to the left of the pump. Don't do like me and try to empty as much water first or you'll have an inch of water in your laundry roon when you twist off the cap.
Sep 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE frontloader door gasket ripped
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
Nov 09, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
841 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
