Question about Apple MacBook Mac Notebook
Macbook heating problem
My macbook really heats up, this is way above normal heating, how to fix this problem?
  • 4,889 Answers
Check if the rear exhaust vent is blocked. This is the most common reason for over heating in mac books. Apple has given this statement regarding this.
Also, MacBook Pro owners still experiencing overheating issues may want to update their firmware. Information Weekwrites about the mysterious update that fixed overheating issues onMacBook Pro notebooks. I have to say my notebook is running a lotcooler since the update.
Posted on Sep 02, 2008
How fix motherboard after water get inside MacBook Pro A1425? dont startup!
Dammage caused by water only can be limited by a special service centre. By heating the system only will have more damage. And even with a scheme you won't be able to repair the macBook. You could try to order the part that is damaged. To see how to open an macbook and how to replace parts, goto ifixit.com. They did lots of repairs. There are moors sites where you can see how to opener (and close) a Mac, but star with them.
Jun 18, 2014 | Apple Macbook Pro Retina 13" A1425...
Tip
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
on Jan 29, 2016 | Apple Macbook Pro 13 - Brushed Titanium -...
Won't turn on
This video may help you
Apr 13, 2014 | Apple MacBook Pro Notebook
Over powering issues
It sounds as though the IO Board is bad. Personally I would sell it on eBay for parts or Repair only. Take the money and buy another working unit. Or you can go here MacBook Air 13 Mid 2013 Heat Sink Replacement and check out this iFixit repair site . This is going to be a lengthy repair, but following the instructions you should be able to do it. I used the HeatSink repair, but you can choose any of the listed repairs for this item.
Feb 22, 2014 | Apple MacBook Pro Notebook
MacBook Pro 17'' Mid 2010 HEAT
if it doesn't get very hot, then everything's fine. Yes, you may try unplugging and see if it works.
Of course, it's better to call the Apple Support. Ask them about the problem and see if it is normal/not.
Jun 04, 2013 | Iomega eGo Portable 35814 1 TB External...
I accidentally spilled nail polish remover on my macbook. it works fine now but i've noticed the fan runs more frequently now. is this normal?
it's possible you got some inside your mac. When it heats up, can you smell the remover? It might be that it dried inside and is being reheated every time you use the mac.
Jun 03, 2012 | Apple MacBook Mac Notebook
HI MY NAME IS JANINA . MY MACBOOK BECOME VERY WARM DURING NORMOL USE . I KEEP SAME PLACE ON MY DESK.
All laptops warm up during normal usage due to the moving parts in a hard drive and the system heating up doing what you want it to do, for the most cases this is normal but when the macbook gets too hot and feels like it wrong could be a problem with your fan is blocked up and un-able to blow cool air into it due to the blockage, to fix this problem you would have to download the service manual on how to access your fan to give it a clean or by taking it to a computer repair shop for fan maintenance although this is chargeable and if you are comfortable doing it yourself then you will need to be careful, If you need further help please ask and if i have helped you please rate me. Kronoguy
Jul 10, 2011 | Computers & Internet
The fan on my macbook has turned on and the battery icon shows an X when it appears. Also when the charger is plugged in the light is a very dim green.
The green light on your power adapter is normal, this indicates that it is charging the battery. The fan within the MacBook is controlled by an internal heat sensor. The fan inside will speed up and slow down based on the internal temperatures.
The X icon for where the battery is, indicates that the battery is not connected or the system doesn't recognize the battery anymore. Meaning, you will need to buy a new battery for your computer.
Nov 14, 2010 | Apple MacBook Pro Notebook
When I start up my MacBook it goes through the normal process, but then I only have a blank blue screen and there is no dashboard on the icons.
Corrupt startup files- cheap fix.
Logic board issues expensive fix.
1) Try removing RAM chips and reinserting snug.
2) Try installing disc 1 and repairing permissions.
3) Try re-installation of software OS.
4) If the above didn't work, then your fu.k.d old chap.
Mar 18, 2010 | Apple MacBook Mac Notebook
Macbook extra fan
The real issue seems to be that the system firmware designers haveoptimized for a quiet machine at the expense of the temperature. Theeasiest way to fix this? A firmware update,perhaps not unlike the one released recently with almost no details.Several reports from users indicated this update increased the use oftheir fans and fixed their heat issues. Isn't that an astonishingcoincedence?
Although Apple said that the update was to "System Management Control(SMC)" firmware, it was up to MacBook Pro (MBP) users to figure outthat SMC is the specialized controller that manages thermal and power conditions, and is in charge of running the portable's fans.
Within hours of the update, users began reporting that the updateseemed to increase the MacBook Pro's use of its fans, and usingdiagnostic tools, claimed that their machines were running up to eightdegrees cooler.
Click on blue link to update and fix fan issue.
Jan 29, 2009 | Apple MacBook Pro PC Notebook
Apple MacBook Mac Notebook Logo
425 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
