Question about Akai LCT2662 Television
Akai LCT2662N Channel Changing Problem
LCT2662 will not change channels properly when entering numbers of channels. It will change the single digit entry, but when changing double digits entrys, such as 32, you will get channel 3 then it will switch to channel 2. I have called the Akai support number, but they told me to have a TV shop check it. I have put new batteried in the remote.
There is a button that controls how many digits you can enter. it is located betwwn the 0 and source or below the 8 buttons
Posted on Mar 30, 2009
When i push the channel 3or any other button then it appears this 3- or 5- or 1- and then if i push an other button it tune in channel 33 or 35 and not in channel 3 or 5 or 7
Many sets for single digit channels you only have to press the number or press a zero and the number--if double digit channels work correctly try on single digit ones zero and the number.
Dec 17, 2012 | Samsung Televison & Video
Can't change the channel on RCA TruFlat. It just has a blue screen and says "14-3"
That RCA TV has only an older analog tuner, so if you're still using it for off-the-air reception you'll need to be using it with a digital converter. I'm assuming you are, since you say there's a channel number 14-3 being shown. The only way you'll see such a number is if it's coming from a digital converter, which will be sending the signal to the TV on channel 3 or 4 (on the TV's internal tuner).
There are several possibilities. One is that the converter isn't changing channels when you use its remote control. This is often caused by weak batteries, so try a fresh set. If your model of converter has channel up/down buttons on it (some do, but many require the remote for everything), try changing the channel manually.
If the converter isn't changing channels, you should try rescanning. The channel memory may have gotten cleared or corrupted for some reason. Also be sure the antenna is properly connected. With digital broadcasting, no antenna means no picture, guaranteed.
If everything else seems to be correct and the converter isn't finding any channels, you'll need to replace it. Unless it's still covered by the manufacturer's warranty or you have a replacement plan from the seller, you will need to purchase a new converter. They weren't designed to be serviced.
Nov 28, 2010 | RCA TruFlat 27F520T 27" TV
I have an Akai PT5492S television that I don't know the v-chip password to and need to reset the v-chip password.
This TV is fitted with a V-CHIP controller which provides you with channel viewing access controls
and restrictions. This function is to prevent your children from watching violence or sexual scenes
that you may choose to exclude.
Press the MENU button and press the SET + or – button to select the V-CHIP SET option,
then press the ENTER button.
Enter your password (4 digits) using the Direct channel selection buttons (0-9).
In the event of entering incorrect password press the RESET button. Then press the
ENTER button.
Enter the same password for confirmation, then press the ENTER button.
Press the SET + or – button to select the V-CHIP option.
Press the ENTER button to select the ON.
Press the SET + or – button to select the TV RATING or MOVIE RATING option. Press
the ENTER button.
Press the SET + or – button to select the desired rating for the applicable video or TV
channel. Press the ENTER button.
And to change or put in a new password:
• If you want to change password, follow steps 1 and 2 and select "CHANGE PASSWORD"
option then enter your new password.
• The V-Chip function is activated only on programs and tapes that have the rating signal.
• Once you block a program using the V-Chip function, the blocked program cannot be watched
based on the content of the show. When the program starts, the "INPUT PASSWORD" will
appear on the screen. When you want to release the V-Chip temporarily, enter the password.
If you change the channel or turn off the TV while the V-Chip function was temporarily released,
the original setting will be resumed. If you return to the channel you were watching you must
re-enter your password to temporarily release your V-Chip function again.
• When you watch the TV from the cable box or the VCR with the RF Modulator, then you release
the V-Chip temporarily, the V-Chip setting will not be resumed until you turn off the TV. The
TV channel is not used in this case.
• When changing the channel with the cable box or the VCR, approximately 10 seconds will
pass until the program appears.
Feb 13, 2010 | Akai PT5492S 54" Rear Projection...
Can only change the channel to single numbered channels.
Three dash option does mean it will look for three numbers. You would then have to put in three digits, so for example if you want to go to channel 31 then key in the numbers 031, for channel 42 key in 042, If you want a lower such as channel 8, then key in 008. Try this.
Aug 04, 2009 | Televison & Video
Cant get a answer on how to program my pro-97 scanner
here is a quote from the manual; hope it helps you.
1. Press MAN, enter the bank (0-9) and channel number (00-
99) where you want to store a frequency, then press MAN
again. M and the bank and channel number appear at the
upper left corner of the display (for example: M000).
Press FUNC. Then press e or d. The bank number moves in
the direction of the arrow pressed.
Press FUNC. Then hold down e or d. The bank number
moves continuously in the assigned direction.
Press e. The channel number moves upward one by one.
Or, press d. The channel number moves downward one
by one.
2. Press PGM. M changes to P.
3. Use the number keys and ./DELAY to enter the frequency
(including the decimal point) you want to store.
If you make a mistake, press CL to delete a single digit or press
and hold CL about 2 seconds to delete all digits.
4. Press ENT to store the frequency into the channel.
If you made a mistake in Step 3, Invalid Freq. briefl y
appears and the scanner beeps when you press ENT. Start
again from Step 3.
Your scanner automatically rounds the entered frequency
to the nearest valid frequency. For example, if you enter a
frequency of 151.553, your scanner accepts it as 151.550.
May 27, 2009 | Radio Shack Pro-97 Handheld Scanner
LCT2662 Remote needed
AKAI E7501-050001 (#E7501-050001)
TV REMOTE CONTROLFor use with model #s: LCT2662, LCT2662N
Oct 21, 2008 | Akai LCT2662 Television
Most Regency Scanners have the same basic programming setup.
Try the following.
Press "Manual"
One of the channels will show up in the display, probably channel 1.
Enter the frequency you want to enter, example 162.550
Press "Enter"
The channel number will flash,
Enter the channel number you want to put that frequency in, example to put that frequency into channel 4 enter the number 4.
Note that on some models for channels 1-9 you must enter the channel as a 2 digit number so enter 04 for channel 4.
You can repeat this process to enter all the frequecy's you want and just change the channel number.
Also check out
for scanner and old radio manuals.
from WikiAnswers
good luck
Dec 06, 2007 | HP PSC 1410v All-in-One Printer
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
TV changes channel changed before all numbers entered in remote
Possibly you're not hitting the numbers fast enough or there is a problem in the delay circuit in the microprocessor. Stargazer
Mar 02, 2007 | Zenith H32G48S TV
Possibly you're not putting the numbers in fast enough. If you are then there maybe a problem with the microprocessor responding too quickly to commands. I've never seen this problem before, but my TV will do the same thing if I don't get the numbers in fast enough. Stargazer
Mar 02, 2007 | Zenith C27V36 27" TV
Akai LCT2662 Television Logo
202 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
