Question about GE GSS20IEM Side by Side Refrigerator
Frost build up on the back wall of the freezer
I have frost build up on the back wall of the freezer and the temperature of the freezer and fridge are not cold enough. I unplugged and thawed the freezer out and tried again with the same outcome. I have cleaned the coils underneath and anything that may have been behind the refrigerator. Any suggestions as to what might be the problem? It's a side by side, model # TFX22QPDA WW.
  • 2 more comments
  • Guiffre Sep 02, 2008
    Thank you very much.
  • m_ld Sep 20, 2008
    frost on back wall of freezer and refriderater is not very cold..where are the coils located at.cleaned everything else
  • ljardine Nov 08, 2008
    Mine has the same thing. Worked fine yesterday. I actually took part in the class action lawsuit against GE concerning this very fridge. They denied my request for a new refridgerator, but extended my warranty for a year. Which conveniently, just ran out. My food in my freezer is thawing, my fridge, I've resorted to coolers until Monday when I call Consumer's Relations. Called for service, but my appt. isn't until 11-14-08, and I'm supposed to do what til then? I talked to 3 different people today, and all 3 of them got a piece of my mind. I am beyond ticket with this piece of ****. I bought it at the end of 01, recieved replacement end of 02, after countless resends of a "revised version of the ice bin". Yeah, not so much. I think I've recieved them 5 times. So, now we have to go to either Monday or say screw it and go to Lowe's and NOT by a GE!! I will do research before shopping for a new one. Good Luck!
  • Anonymous Mar 15, 2014
    GE side by side back freezer wall is all frosted ?
  • 4,889 Answers
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Posted on Sep 02, 2008
Code H1 on my frigidaire ffhs2622mwla refrigerator
HI is an error for freezer temperature detected as too warm... Look for frost on the back wall of freezer (defrost failure), or a failed evaporator fan (you should hear it running in the freezer compartment), if the food in the freezer is beginning to thaw, check the compressor to see if it is running. If the compressor is running, but the freezer isn't cold enough, and the evap fan is good with no frost build-up, you may have a sealed system leak (refrigerant charge is low). Frigidaires really suck in recent years and have lots of leak issues...
Jun 20, 2016 | Frigidaire Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Freezer side is cold but the fridge side is not getting cold
Luispinto243 --
The heat exchanger is in the freezer side of a refrigerator. If the cold air pathway has gotten frosted-up, or the blower is not working, the fridge side will get warm. If possible, fully defrost the unit and the frost/ice build-up will thaw-out and the fridge will start working again. Adjust the thermostat to the energy-saving position. Trying to lower the temperature will not fix the problem. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Freezer wrk OK but temperature in the bottom fridge not cold
If you have a frost build up on the interior back wall of the freezer, you have a defrost issue. This would include a bad defrost control, bad heater or terminator.
If there is not a frost build up then you may have a bad evaporator fan motor.
Apr 28, 2009 | Frigidaire FRT17G4B Top Freezer...
Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Mar 18, 2009 | Zanussi ZX56 / 4 Bottom Freezer...
  • Defrost the freezer
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • If you recently adjusted the temperature control, loaded the refrigerator or are in a humid location, it is not uncommon for a refrigerator to run for 24 hours or more before getting cool.
  • Mar 15, 2009 | Refrigerators
    Warm fridge
    check the fan in the frezer and check the defrost
    Nov 29, 2008 | Amana Refrigerators
    My fridge is not cold enough and the freeze is colder and has ice
    hi. thanks for the question. the drain tube that goes down to the drain tray is clogged. turn fridge off .pull fridge from wall. remove back panel clean all coils. let it thaw with doors open, it will thaw quiker. when thawed, clean the drain tube. this will solve the problem. thanks the appliance doc
    Sep 28, 2008 | Refrigerators
    Bottom mount freezer not getting cold enough
    You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
    Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
    GE GSS20IEM Side by Side Refrigerator Logo
    1,520 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
