Question about Sony Mavica MVC-CD400 Digital Camera
CD400 and IR
Has anyone tried Infrared photography using a CD400 or other CD Mavica camera. I have tried the test where you place the remote control in front of the camera and the light shows up in the LCD. I was just wondering if anyone had any real world experience and advice for getting good results before I go out and buy filters. Thanks. William
    Master:
  • 551 Answers
Yes, it'll work. You'll want to get the Hoya RM72 filter. I think that it's 52mm that attaches to the VAD adapter.......I've slept since then. If it's 55mm then order that one of course. There are other choices in filters but the RM72 has a fairly generous cut off that will give you more light to work with than a RM90 for instance. Exposures will be longish (seconds) at f5. I generally shoot at ISO 100 but you might find that ISO 200 works a little better. Play with it, after all the film is free. The results will be deep red and you'll have to use your photomangler to desaturate. Sometimes I adjust levels and sometimes a little noise reduction is necessary. The best times for shooting are in the morning or evening as that's when there's lots of IR. Do not expect to take pictures in the dark. Were talking near IR not the heat imagers. Enjoy.
Posted on Sep 13, 2005
    Master:
  • 551 Answers
Check it by point the lens at an IR source, like a remote control. Click on the remote, if you can see the IR light in the LCD finder, then the camera is sensitive to IR and should work. I think it will. The specs on the CD400 is almost completely the same as the S85 (excepting the obvious differences) and it probably has a lot of the same guts.
How do i check if the (ir system ) works on my ac unit that i have no remote for so i waste money on a new one??
IR Remote controls use invisible Infra Red light
I often use the camera on my iPhone (in Camera Mode) to see the invisible light.
A computer Camera should work too!
The camera see's the IR as a white light on most cameras
Check it out.
Or the Expensive
infrared viewer
SIMPLEST IR REMOTE TESTING CIRCUIT
Computer Camera
How to test IR remote controls
Make your Own
Remote Controller Tester An Amazingly Simple DIY
Feb 13, 2016 | Audio Players & Recorders
I need to replace the infrared sensor unit for Vizio L37 HDTV.
Good day!!!
Before I answer your question let me clarify something..
  1. What sensor you need to replace is it on the remote IR (infrared) or the receiver on your TV?
  2. Did you try other remote control?
  3. How did you say that you need to replace the IR sensor or receiver on your TV?
To test the remote please use a digital camera..How? place the shot to infrared of your remote then look at the screen of your camera after that press any button on your remote and look if the IR sensor lights up..
Please answer all my clarifications for me to diagnose the exact problem..Because replacing of IR sensor on TV is difficult..
Thank you for using fixya and choosing my service..
Dec 11, 2011 | Televison & Video
Sony Mavica CD400 orange vertical line appears.
In lesser digital camera chips, this is typically "vertical smear". It is especially apparent if there is a much brighter light source in the image. I.E., a street lamp on a dark street. I have used an early version of the Mavica and experienced this type of situation with that camera, so am assuming that this is typical throughout the Mavica model line. The work-sround is be particular about the lighting situations you shoot with the camera.
Jul 08, 2009 | Sony Mavica MVC-CD400 Digital Camera
Sony CD Mavica MVC-CD400 display/backlight faint/not working
If you already tried to adjust brightness and it didn't work, problem is backlight inverter which is part of DC board or it might be fuse on DC board related to inverter. Anyways, camera needs to be serviced.
Mar 18, 2009 | Sony Mavica MVC-CD400 Digital Camera
Problems retreaving pictures from my old cd mavica disks
If your mini-CD is damage it is a very difficult problem. You can also try using cd image cloning softwares... ^_^
Jan 12, 2008 | Sony Mavica MVC-CD400 Digital Camera
I just can't get it to work, new batteries and all.
First check if the remote control is sending an infrared signal. If the LED is flashing, this does not mean the Remote control is sending the IR signal. There is a separet Infrared LEd that sends the signal. To check the IR, point the remote control in a video camera or any camera with real-time monitor (phone cam, webcam, etc.) and press any button. You will see a white flash coming from the Remote control. thjis works best if the camera is black&white, for color camera, the IR is still visible but quite faint. Another way of checking the IR (if you do not have a camera) is to press the RM in front of another device with remote control and while doing so, press the correct remote control . If that other does not function or functions erratically, then the remote control in question is emitting an IR signal. If there is no IR coming out, the solder conection of the IR LED might be the problem. It is rare that the IR LED will be damage because the remote control is only 3 volts. If the remote control does emit an IR signal, then the TV remote reciever is defective. I had this problem with a CD player that I have fixed. The IR reciever looks like an LED (dark colored) with three pins (V+, signal, ground). Cost less than $3
May 18, 2007 | Jensen JER-323 Remote Control
Mavica cd400
To review the picture just taken - seconds; to retrieve from the disk you have to finalize the disk which takes about a minute for a full disk, seconds for a partially filled disk. Then you just put it in your CD-drive and you can view them immediately. If you have Roxio with a CD-RW you may not have to finalize the disk first, and you always have the option to transfer pictures via the USB cable (same as with other digicams).
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Sony Mavica CD400 -- can't get iMac to see mini disks
Bob: the Mac will never show what is on the disk.....and you don't hgave to finalize either. Do you have Image Capture on your units? If so, all you need to do is connect the camera via USB cable to the computer. The program will come on automatically (the camera has to be on), you can choose to download some or all of the pictures to a folder of your choice. HTH
Sony Mavica MVC-CD400 Digital Camera Logo
78 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
