Question about GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
Ramsond split AC 12000
I installed it in July-08. It worked for few days with water leakage from starting point( inner unit). The flow level was perfect and i couldn't figger it out the fault. Now it stopped working no cooling atall showing error E4 ?
Pls advise.
HI YOUR BROBLEM I THINK IS THE SENSOR FOR THE ROOM TEMP
Posted on Dec 05, 2008
How do I check if a current overflow' problem is due to the Sensor or the Rainbank?
take the sensor above water level--say in a bucket of water then lift it out of the bucket
if the mains water flows or stops flowing depending on whether the sensor is in or out of the water will indicate it sensor or solenoid of the rainbank
I suspect that the sensor will be a simple float arrangement filled with mercury so that when it is hanging down ( no tank water) the mercury bridges a set of contact points and makes a circuit and when it get to a fill point the mercury flows away from the points and so breaks the circuit
Sep 28, 2016 | Washing Machines
Installed new dishwasher, not working properly
If it is an LG:
ERROR DISPLAY [E I ] Leakage error. Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
Apr 01, 2015 | Dishwashers
Leaking water from the inside unit
When the air gets cooled it also gets dehumidified, on the inside unit there should be a condensate drain. Check the drain to see if its clogged, also check to see there is a drain, I have seen units installed by "pros" who have forgot to intall it
Apr 14, 2014 | Ramsond 12,500 BTU 1 Ton Ductless Mini...
Water leakage
Your not to clear about your problem. First I need more information. Is it a window unit, or through the wall or a split unit???
Usually when there is water leakage from a window or through the wall unit there could be one of two problems. One being a clogged area in the condensate pan not allowing the condensed water to flow out of the back of the uinit, or two, the unit is not properly tilted outward to allow the water to flow outside.
If it is a split unit and it was previously working fine then it most likely is stuffed with debris and should be cleaned out.
Good luck, I hope I have helped.
Marty
Apr 04, 2014 | Whirlpool Heating & Cooling
The unit was working filled up with water and then quit working. The LED's flicker but it doesnt turn on
It ispossible that the machine does not start off the cycle because there are errors possible failure of the controller unit. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.
Aug 03, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Haier model HLP21E. The wash cycle doesn't seem to do anything but the rinse cycle and spin cycle work well.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Click this link: Inlet valve
Jun 25, 2012 | Haier HLP21E Top Load Washer
After years of perfect operation the water reservoir tank needs to be emptied every few hours. Is is almost a gallon of water each time. The normal time was always every other day ...at most once a...
12k BTUs will condense a gallon an hour easily, sounds like the problem is with a probable self-evaporating portion of the condenser. If so either the inner workings of that unit are dirty/malfunctioning or the exhaust duct is not getting proper airflow. If you're mechanically inclined I'd recommend pulling the unit apart and cleaning the condenser parts. If not perhaps try attaching a permanent drain hose to the drain plug. Definitely check the exhaust duct either way.
Sep 22, 2011 | Amcor ALTL-12000E Portable Air Conditioner
Have the Toto Ultramax II toilet and it was installed 3 months ago. Have an issue where the GMAX fill valve is not functioning properly. The water keeps running because it always go over the fill line....
An installation guide for your toilet can be found here:
http://admin.totousa.com/Product%20Downloads/0GU013Z,%20ONE%20PIECE%20TOILETS,%20V.08.pdf
See the top of page 5 for guidance on setting the water level. Make sure you are turning the screw the correct direction (clock-wise) to reduce the fill level.
Is the refill tube properly connected? Should be connected to fill valve nipple and the other end clipped to direct flow to the inside of the overflow pipe.
Is water flow only through the overflow tube or is there leakage from the flush valve? Being only 3-months old you should not be having problems due to breakdown of rubber seals; however, check to make sure the toilet flapper is properly sealing against the flush valve.
If none of this helps with your problem you made need to replace the fill valve. On page 10 of your guide is a parts list; you can identify your part numbers and shop on-line for an idea of replacement costs:
https://www.totostore.us.com/e2wShoppingCatalog.aspx?parentId=3100066448&parentLink=2100000107:3100066448
Jan 19, 2011 | Toto MS853113S#11 UltraMax Round Toilet,...
My car keeps overheating what should i do to solve the problem
1 Check if the radiator fan is working properly. 2 Check the level of coolant in the radiator. If less top it up. 3 Check the oil level. May be the oil is less. If so top it up. 4 Check the water hoses are connected properly and there is no leakage at the connecting points. 5 Get the fins at the radiator cleaned up to allow free flow of air. 6 If all this OK and the car is still getting overheated then either the water circulation pump or the oil pump is not functioning.
Jul 02, 2010 | 1996 Chrysler Town & Country
Hi I have 1.5 ton samsung split ac. The problem is to solve the water leakage in the indoor unit. Kindly advise
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
May 19, 2010 | Samsung AS1293L Air Conditioner
GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0 Logo
988 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
