Have the version Windows 95 & higher. It will not install on new
computers, desk and lap top. Can it be fixed? Or is a newer version
of game disc be acquired?
Where can a new version be found? There were at least 10 games on 100 Solitaire that I played on a regular basis>Same answer received from Office Depot.
a regular basis>
Good day, most of the Microsoft games and apps for windows 7 and before 7 don't work on windows 8 an above, i suggest that you go on you app store and download a compatible version for your pc
It should, if its designed for Windows xp you should be fine!
If it does not work/says you have 64bit try right clicking installer click properties, compatibility and set to windows xp.
When you do that install it.
Right click the exe and repeat the compatibility stuff. Tell me if it works.
Older products aren't compatible with newer OS. The best way you can play these games is probably by emulating a virtual PC. Try installing Windows 98 on a Windows Virtual PC.
you can try running it in compatibility mode, when installed right click the desktop icon, then go to bottom of list to properties, then on the thumb nails, look for compatibility look in the list for what ever program it was made for ie windows xp, windows 95, then try that there are more settings there which may help...hope this helps
Once you insert the CD, go to Start -> My Computer, and Double Click on the Drive that has the Hoyle Picture. This will either start the Installer/Auto-run window, or it will open a series of files. Double click on Setup.exe if it does not autorun.
Windows Vista Home Premium is on both computers
a regular basis>
Thanks for the assist. It is appreciated. Will contact you again if help is needed
for other problems.
Lou
