Question about AEG Dishwashers
AEG Dishwasher 35080VI inbuilt - door pops open
Hi
the door pops open on this machine when we set it up to dishwash. Hence the machine is not working.
Any ideas as to what might be wrong?
thanks
Christine
02380 452883
    President:
  • 1,462 Answers
Usual door closure is onto a hook coming out of the top of ther cabinet just under the worktop. this needs adjusting to come out a little
Posted on Sep 02, 2008
Favorit 40010 vi dishwasher the machine door opens during the wash except on eco 50 wash
Strange it remains closed on one stage? Usually a door that opens by itself is due to misalignment, and then gain water will leak onto the floor. If someone banged into the side of the door and moved the washer a slight bit, the locking tab under the work counter may not be in a positive position. If the tab is bent slightly up, the door may barely make contact and lock when in operation. A simple movement of the washer could pop the door open. Other than that, any electrical dysfunction would require a professional servicemans attention.
Mar 17, 2014 | AEG 23 in. Favorit 44070Vi Built-in...
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
AEG Favorit 35080vi is not heating water
Hello
You need to take the machine out and remove the top and side panels from it.
(If it's integrated there's no top).
Once you have the side panels off, remove the water in the base of the machine.
Dry out the electrics
Once dried out, try the machine again.
If it doesn't trip and starts working, watch to see where it's leaking from.
Locate the leak, cure it and that should rectify the problem.
Hope this helps
Jan 26, 2012 | Dishwashers
Why does my dishwasher keep popping open during a cycle?
Hi, the problem is that there was too much resistance to the door closing. You have to pull off all the rubber gasket that press against the door, clean it well, re-installed it and the resistance will go. It's a easy permanent fix, just do not stretch the gasket as you put it back in.
Jun 22, 2011 | AEG Dishwashers
The AEG dishwasher not heat the water.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jun 17, 2011 | AEG 23 in. Favorit 44070IW Built-in...
Aeg dishwasher detergent door won't open
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Mar 20, 2011 | AEG Dishwashers
Antiflood system triggered-how to reset on aeg favorit 35080vi
Hello everyone. Have just fixed a problem with my aeg dishwasher thanks to this site. My anti flood switch in, so I unpluged, pulled the machine out, tilted it, wiggled the outlet hose, which I think was a little kinked and way hay it works. Thanks FIX YA. Good luck everyone. Carolyn
Feb 08, 2009 | AEG 23 in. Favorit 88070IM Built-in...
AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Sep 25, 2008 | AEG 18 in. Favorit F54850 Slim-Line...
Error code 30
i fixed the problem by tipping the machine over slightly, as suggested by other members, about a pint of water came out the bottom and it now seems to work perfectly.
Mar 27, 2008 | AEG 24 in. Favorit 60870M Free-standing...
Dishwasher is on before I physically switch it on
Support AEG Australia
I don't know what "the timer? has gone" means. You can't clear the timer or reset it? I would call their support. There is also support in the UK. But you can take a look at the following page:
http://www.instructables.com/id/How-to-repair-your-AEG-or-Electrolux-dishwasher
No diagnostic codes?
Error codes for AEG Dishwasher
Oct 29, 2017 | AEG 18 in. Favorit F54850 Slim-Line...
Dishwashers Logo
632 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
