Question about HP PSC 2210 All-In-One InkJet Printer
Scanning, pc connection
My printer will print, but it won't scan. Also, I have tried to use the installation disk (which is compatible with my OS (Windows XP professional), but the disk drive doesn't read or initiate the installation process. We have had this printer and Dell computor since 2001, and it has worked fine... can you help?
  • Anonymous Sep 15, 2008
    I have same problem :-(
  • 4,889 Answers
Well thats looks more like a driver problem. Since you are not able to read the cd here's an alternate location for your driver. Click here to download.
Posted on Sep 02, 2008
Why does my canon PIXMA 452 say pc not connected when I hit the start scan button
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
Jun 09, 2014 | Canon Pixma MX452
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
My printer is printing but i cant scan my documents - no compatible printer installed
Make sure the Lexmark OCR scan software (used to scan documents, convert into PDF file or create multiple pages into 1 file). The software is available on the installation disc that came with the printer.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolve your problem, your rating will be greatly appreciated. Thanks.
Oct 20, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
My lexmark x1240 all-in-one will not print. It saves XPS files and when I go to open them it will not open them. I have already installed the XPS reader. Also, when I try to scan, a box pops up saying...
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lgJCxt. Select your operating system, download and execute the file.
Try to scan again to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support for additional assistance.
Oct 11, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
Restart your computer.
Download the proper drivers.
XP Drivers
Vista 32-bit Drivers
Vista 64-bit drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
If using Windows 7, use the Vista drivers in the compatibility mode.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on)
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
Mar 04, 2011 | Computers & Internet
I installed my HP printer/scanner C4472 in my new computer from the disk and it prints from the computer but it does not scan. When I click on the Centro Solution HP icon I get a message that says the HP...
You need to download the full software that's is compatible with your laptop OS ! This complete software has the full features driver embedded and installed once and for all ! Please note it has to be compatible with your Laptop Operating System ( windows 7 , windows 8 etc ) support !
Sep 06, 2017 | HP Office Equipment & Supplies
Juat starting from scratch on scanning. When I
Install the HP software from the CD-ROM disk that came with the printer, to enable the "scanning" function (as you say, the "printing" function is working fine).
Jan 29, 2010 | HP PSC 2210 All-In-One InkJet Printer
Printer x6570 won`t print photos and data, or scan...
try uninstall the driver and insatll it after that reboot and connect printer!
Jun 05, 2009 | Lexmark X6570 InkJet Printer
Lexmark X1185 (print trio) does not scan or copy since upgrading to Vista
Hello Barbhinkins,
Please find the vista driver for this printer at this link. Follow the instructions to install properly.
Hopefully this file will also have driver for scanner.
Thanks,
Lolita
Aug 15, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark printer x3430
seme perdio el cd para istalar la impresora lexmark x3430 y lo nesito para istalarla en otra computadora donde lo puedo descargar
Dec 31, 2007 | Lexmark X5470 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
37 people viewed this question
Ben Johnson
