Question about Sony Mavica MVC-CD400 Digital Camera
Messed up CD400 resolution
Okay, my CD400 was taking pics at a 300 resolution but now it takes pics at 72!!!! Why is that. I'm doing a photoshoot on monday and i need to know! Please help me, thanks, molly
    Master:
  • 551 Answers
Hi Molly, The 72 ppi figure is merely an arbitrary starting point used by most image editing software. I've known others to use 300 as a default, e.g. Paint Shop Pro last time I looked at it. Why it should have changed I can't tell at this point, unless you've changed your software; but it's not important. The figure is meaningless until you want to *print* your images, and even then it's best to just set print size *without* resampling the image, and let the resolution look after itself until you have a need for very large prints. To see what your camera is capturing, the essential figure you need to be interested in is the images' *pixel dimensions*; and in the case of the CD400 they should be 2272 x 1704 at the camera's full res. setting. (Actually, "resolution" is an unfortunate term, in its popular usage. Resolution really describes how thinly or densely the same pixel count is mapped over the intended physical output size.) Changing the print size *without* resampling the image will cause the resolution figure (72, 300 or whatever else it might be) to change inversely with the print dimensions, but will not change the overall pixel dimensions of 2272 x 1704.
Posted on Sep 13, 2005
Haing taken photos on what was thought to be the 'large' setting the photos have come out only 72 pixels and I want to know if it's possible to change them into 300 pixels. or if not possible, how do I...
Set your camera to take pictures at the maximum megapixel level. Later, if you need to lower the resolution of your pics for whatever purpose, you can do that in any photo-editing program.
Aug 01, 2010 | Cannon Cameras
How do I change the resolution of a picture in Appleworks?
just re scan it and change the setting make it 300 dpi
Mar 05, 2010 | Apple iMac G3 (1999)
Why does the FinePix E510 pictures download from the camera at 72 dpi when the camera was set to take 500 megapixel photos? I cannot find any way to adjust this in the finepix manual or in online help. I...
A couple of things - I don't think you mean 500 megapixels (that is a lot!) but I assume you mean you expected a high resolution image. You may have it! The dpi setting is largely irrelevant (for photographers) as it simply relates number of pixels to a (notional) print size. Thus an image that is 3000 pixels wide (say) would print out to 10 inches at 300 dpi (3000/300) or 40 inches (approx) at 72 dpi (3000/72). the image has the same information /resolution - it's just "spread" further on the larger print. You can easily change the nominal dpi in e.g. Photshop Elements but it won't affect your image quality.
If however you are getting low resolution images when setting the camera differently that's something different. I would need extra info to help there but pssibly check if the camera was set to RAW and maybe you were looking at the (small) JPEG usually saved with it?
Jun 27, 2009 | Fuji Finepix S5800 Digital Camera
I have a text image in cursive writing. the image size is 72 DPI. I need a way through which i can run this text image & get good 90% to 100% accuracy over transformed text. The problem is whenever i run...
Hello strivastav_p,
It sounds like you are attempting to increase the size of the image. You can do this, but you will always lose resolution. 72 DPI is 72 DPI. It cannot be increased to 300 DPI. Think of it like this:
You have 72 pieces of candy that fit in a small box made to hold 72 pieces of candy, and it looks like you have lots of candy.
Now, you get a big box that can hold 300 pieces of candy and put the same 72 pieces of candy in it. It no longer will look like you have a lot of candy.
Image resolution works the same way. The only way to get the text to be clearer is to scan another copy of it at 300DPI and then do what you need to with it.
Hope this helps!
Jeff
If this response answered your question, please rate it. Thank you!
Mar 12, 2009 | Computers & Internet
How do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Resolution
Many cameras will take pictures at only 72 dpi. Changing the resolution causes the camera to change the size of the picture in terms of pixel dimension (ie 800x600 vs 640x480) but always at 72 dots per inch. A photo editing program like Photoshop can change the resolution to whatever you need.
Dec 13, 2007 | Samsung Digimax 4010 Digital Camera
Adding pictures to my contacts' info.
You have to take the pictures in 72x72 format in order to use them for your contacts image. I finally found this after looking on numerous websites. I tried it and it worked. The bummer thing is that you have to take the pictures that you want to use all over again.
Sep 13, 2007 | LG KG800 Cellular Phone
Canon Rebel xti vs Photoshop!
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
In need of SERIOUS help with CD400 Battery, etc.
I don't know how long the battery lasts if you use the flash with every picture, but I do know that the CD400's battery charger can take 110 or 220 volts so you will be able to charge it in France with only a plug adapter.
Sep 13, 2005 | Sony Mavica MVC-CD400 Digital Camera
Sony Mavica MVC-CD400 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
