I have a Hotpoint BWD12 1200 spin washer dyer. 2-3 year old.
The program selection knob keeps turning, the manual says to just reset, I've followed the instructions to the letter but it keeps happening.
Any one have a solution or an idea of how to fix this?
Thank you,
Derry
SOURCE: Hotpoint DC28 Dishwasher Problem
u will more than likely find its the element... and i would not charge that for to come out.. ive one here im doing.. u can get the part for 40 quid on the net.. im charging to fix this one 90 in total. let me know what happenes
SOURCE: washing machine
The knob keeps turning when you have a problem with the machine the most common problem with indesit is the pump. check to see if there is any thing in the filter compartmet located at the bottom on the front of the machine if so clean and replace.. THEN you will have to reset the knob. you do tis by turning the dial to one of the off position (the big black dot ). Then leave the door open and keep switching the machine on and off quickly from the button on the front of the machine untill you c the lights flicker rappidly.. once this happens the machine is reset and ready to wash ... p.s The pump can be one source for a problem... others include brushes on motor.....but most likely it will be the pump tell tell signs are water in the drum
SOURCE: Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
SOURCE: right ascesion slow motion control knob loose, does not work
The RA knob has a setscrew that fixes it to the shaft. Just need to find the correct size and tighten.
SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
Fixed!!!
The load was too heavy!
The PC board must have had an error during the initial stage of a wash.
All the clothes got wet, when I reset the PC board the system wouldn't work cause it was too heavy.
Thanks anyway.
Der
