Question about Hunter 52" Ceiling Fan With Light And Remote Control
The remote control on hunter ceiling fan mod. 28870 420
I have had the fan for a couple of years now and working beautifully. I have always used the remote, never turned the power off to the fan. The light started coming on by itself. I would turn it off with the remote and sometime later, the light would come on by itself again. After about 4 times of this in about 3 days, I changed the battery. Now the remote does not do anything, no fan, no light. Using the chain pulls, the light will come on and off but the fan does not work at all.
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 163 Answers
SOURCE: Hunter Sonic Ceiling fan comes on by itself
is it your grage door opener that could be doing it
Posted on Jul 26, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
have hunter douglas fan glass globe broke cant find repalcemants i have all the serial no do you no wher i can go to find 91/2 globe
Posted on Aug 20, 2009
  • 4 Answers
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
It's a 3-speed ceiling fan that's for sure. I think the same a fixer1950 already said...
This page about <a href=http://www.ceiling-fan-wizard.com/hunter-ceiling-fans.html>hunter ceiling fans</a> might be interesting...
Posted on Oct 09, 2009
My remote want work, I have a Hunter Ceiling Fan with a remote, I change the battery still not working How can I order another remote the MOD#99123
This might not be the remote. It is most likely the control module in the fan itself. It may be easier to order a whole new fan BUT you can go to any big lumber store and see if they have the whole remote control kit with the controller and remote.
Nov 13, 2017 | Hunter Dryers
THE LIGHTS ON MY HUNTER CEILING FAN WILL NOT LIGHT UP BUT THE FAN PORTION WORKS WELL
If your Hunter fan uses a remote control, the light portion of the remote receiver probably has failed. It is a common problem with remote-controlled ceiling fans in general.
Jan 29, 2017 | Hunter Dryers
Hunter fan 27227 remote stopped working
How i fixed my Hunter #28096 remote controlled ceiling fan, started not controlling the light, then later the fan quit also. Start by testing the remote buttons, see this post... Cp9430r Fixya
Jun 22, 2014 | Hunter Ceiling Fan Light Remote Control
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
How do you set the switch for 3 adjacent ceiling fans
Each remote/fan unit has to be set to a different code otherwise you will always have this problem. Open up one of the remotes and you will see the area where the numbers can be selected, usually one thru five. Then remove the cover on the fan at the ceiling and you will see the same set up. Just go from unit to unit and do not use the same code on any two fan/remote sets and your problem is solved.
Jul 31, 2009 | Hunter Ceiling Fan Light Remote Control
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Dryers Logo
767 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
