Question about Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
My son powered off the Dell 5100 by the push button which was absolutely normal, and it now can't power up. The green LED is lit on the motherboard. Green light on motherboard works. Just a little over 3 years old and out of warranty. I replaced the power cord and used another power extension cord. Problem remains the same.
Give me hints. Thank you a million.
Jay Jin
Jiankangjin@yahoo.com
  • 2 more comments
  • jayjin Sep 03, 2008
    Pagebor; Thank you for help. Yesterday afternoon the Dell 5100 booted up and everything returned to normal. I told my son if he shut it down, it would not reboot. And it was true.
    I searched if any capacitor has visual breakdown. It doesn't have. I toggled the 115/230v switch, and removed the mobo battery and put it back, it just can't reboot.
    I told to my son, if you turn on the next day (i.e. today), it would reboot and be normal.
    This problem happened one or two days after my son upgraded the Dell 5100 from XP to Vista Ultimate and with the help of Microsoft Assitance installed the SP1. Then the non-boot problem kicked in. Before he installed the Vista, Microsfot check says it is barely compatible, while Dell check says the Dimension 5100 is not compatible for Vista at all.
    Today we will format the C drive if it can be rebooted, and then reveret it to its original XP.
    If I am right, then, the Vista Ultimate is causing the problem, in flooding the Cache, jamming the RAM etc. Once a day's time clears all its content, the system can reboot itself. We'll see.
    Any suggestion? and tell me why this is happening?
    Thank you in advance!
    Jay Jin
  • jayjin Sep 04, 2008
    Hi, Everybody;
    After we formated the C drive, removing Vista, and reinstalled XP, now the Dell Dimension 5100 returned to normal. It just doesn't have any hardware problem, such as mobo, PSU or RAM.
    Jayjin
  • cindyreeves0 Jan 23, 2009
    exact same issue as jayjfn's power problem, shut down and now the power will not come back on.. the green light is on.
  • Anonymous Feb 01, 2009
    i went to turn on my pc today and it will not turn on but the green light on the motherboard will light up please can any one help with this situation thanks
Hi, Everybody;
Jayjin
Posted on Sep 04, 2008
Hi, Everybody;
Jayjin
    Genius:
  • 2,785 Answers
Plz check the ram and powersupply unit and try to reset the bios
Posted on Sep 03, 2008
I have a Dell Demension 5100, and the power button got stuck. By stuck, I mean that the power button is pushed in, but not released. It's stuck as if you pressed the power button, but did not release...
if your PC have restart button then open your PC and check the power cable slots and change them into a reset mode removing reset cable to reset slots and attach to power slot. Then you can power your pC with reset button. If you can open front case then you can outside the button .
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
My sons dell dimension 8400 let out a bang and now no power, the pc had froze and he had pushed the power up button on the front to turn the pc off any ideas?
Can you please describe what happens when you try to power on the system? Have you tried your system with a knwon-to-be-good power supply?
Feb 08, 2011 | Dell Dimension 8400 power supply ** FREE...
Dell dimension 5100 - usb ports on motherboard are broken
Flashing Amber is normally power supply
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
The USB ports are part of the motherboard
Jun 08, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
No power to Dell demension 5100 desktop
If there is no activity whatsoever when you press the power button on than you have likely blown the internal power supply fuse. This will need a technician to repair.
Apr 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Can't power up Dimension 5100
Is this a DELL system? E series ?
Well , you'll have to reseat the memory chip on the motherboard and check for other power connectors.. but please try this only if you're sure that there is NO display at all and the system will just not start up!
Please make sure you disconnect any peripheral devices and the power cable before opening the chassis!
Please rate this post!
Sep 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 power up problem
I had same issue with dimension 5100 Desktop. I work at Circuit City as the Lead Technician. I found that swapping the power supply did fix the problem! When i initially tested the power supply with a standard power supply tester, the power supply appeared normal. But after swapping the PC works great. Thx for the good idea!
Sep 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power supply ?
I'd recommend purchasing a new power supply.
Your Dell Dimension 5100 comes stock with a 305W power supply. This is a bare-minimum wattage that will only handle what they ship on the system & not much more. You're better off upgrading the power supply with a compatible after-market model.
You can go to a PC parts store in your area and take your chances...but they're usually more expensive then Internet sources (they've got to pay for their brick-n-mortar store overhead).
Here's a link for a very inexpensive replacement 400W power supply for your Dell Dimension 5100:
http://www.affordablesurplus.com/dell-5100-5150-power-supply.asp
This particular site offers $8 Flat-rate shipping & a 1 year warranty. Your power supply is only $49.99 - you might be able to find it cheaper elsewhere, but that's the best I could find with a quick Google search.
If my answer helped you, please provide feedback :-)
May 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 won't power on
might be a problem with the power button...try exchanging the power adapter and the reset adapter in your motherboard...this would become:
RESET BUTTON: as power button.
view your manual on where to find this adapters in your board.
Nov 19, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
444 people viewed this question
Alun Cox
