Question about Handspring Treo 180 Handheld
Duplicate in Calender entries
I encounter an error message : DataMgr.c. Line 8589 Index out of range Can someone advice me on the problem, please ? Thank you !
0 characters
1 Points
SE P1i update question.
same question .....................
Feb 04, 2009 | Sony Ericsson P1i
On my Dash, when I synch, I want the dash to be master, not PC
hi.my phone is bestel D5000.my messages in box always empty.plese help me.and tel me how can format and reinstall my phone data(software).give ne best help.
Feb 02, 2009 | T-Mobile Dash Smartphone
Can't sync contact and calender items to outlook 2007
First off, please don't give me a bad rating, as I don't have Vista, and this is simply a guess..
Secondly, Look around in the settings in WDMC, maybe there is a setting to copy contacts on device onto outlook on the PC. Don't bother looking in outlook since the device usually sync with Activesync/WDMC, which does the rest it self.
Jan 07, 2009 | HTC Touch Diamond Smartphone
Past few days I am getting a message when i press Option in Calender : Unable to execute file for securit reasons
First, try a battery pull. For about 30-40 seconds. Re-boot the phone. Try to get back into the calender. Try a soft reset code:
Soft Reset: *#7780#, 12345 and then Yes If the error message continues, do a master reset. This will bring the phone back to it's original status from when you got it out the box. (ex. wall paper, ringtones, themes, etc...). Full Reset: (clears everything off the phone memory!! Be sure to back up your contacts!!): *#7370#, 12345 and then Yes!
The screen may go out, and come back to it's orig. screen. Then, re-try the calender. Youl'll be golden!
Dec 26, 2008 | Nokia E61 Smartphone
Calendar sync
Sounds like either you Service book [CICAL] maybe curropt; delete the service book and wireless sync the device to push new service book.
If that doesn't work; check if your colleagues have the same issue too, it may be a greater issue with the BES. i.e - One way Calender Sync issue.
Ask your IT guy to go through the BES logs to search for errors under your PIN for the day you had made entries on Calender.
Do few Tests - one from the Device and sync and the other on your desktop mail and sync.
I hope this helps, let me know how it goes,
Thanks.
Nov 10, 2008 | AT&T Blackberry Curve 8300 Smartphone
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Please Help
well..try flashing ur phone..!!
or else  restoring it to factor default thing!!
by flashing ur phone will v a DAMN new one..!!
just like formating ur PC, installing new OS.
good luck Sir.
Sep 22, 2008 | Motorola Mobility MING A1200
Fatal Alert
Here is Epocrates answer: "... A fatal error when opening the Epocrates application typically indicates that one of our database files has become corrupt. HotSyncing again may restore functionality. If not, uninstalling and reinstalling our application should correct the problem. Other Fatal Error messages relate to not enough free memory on your mobile device for a complete installation or, your mobile device does not use the correct Palm OS version. Please verify you meet our minimum system requirements by returning to our web site, click Support, and then click System Requirements by your Epocrates application. Delete Epocrates Palm/Win from your mobild device. On your mobile device, tap the clock (located upper left corner of your screen), tap App then Delete. Select the following files (one at a time) then tap Delete. You may not see all of these files on your mobile device. It may take several minutes to delete a file. The file will disappear from the program list or your mobile device will turn off when complete. See Frequently Asked Questions 484 for instructions to preserve your notes * AutoUpdate or Libaupd * Cholesterol * Compendica * DocAlert * DocMemo * Drip Rate * Epocrates * Epocrates Dx * Epocrates ID * Epocrates Lab * Epocrates MedTools * Epocrates Rx * Epocrates MTH * Epocrates Startup * Epocrates Tables * EpoxLaunch * Fahr/Cels * HTN Ref * Insulin Calc * MedMath * MedToolsHack * MobileCME * Natrecor * OnBoardAU * Tutorial * UpdateEmail * Version-ep22 * Any file ending in NC-2 * Uncompressor * Any file starting with SMSH * Any file starting with ID and ending with NC43 Tap Done when finished. Disable the Epocrates conduit. On your computer, click on the HotSync Manager icon in the lower right hand corner of your system tray then click Custom. Double click Epocrates , select Do Nothing and check Set As Default. Click OK. Double click System, select Handheld Overwrites Desktop and check Set As Default. Click OK then Done. HotSync your mobile device to your computer. Locate and double click Epocrates2PalmW.exe to reinstall Epocrates. If you cannot locate this file, return to our web site, click My Account, login, click Epocrates Download then follow the remaining on-screen instructions. ..."
Nov 08, 2005 | Palm Tungsten T5 - Multilingual Handheld
Synch warning
Go to your outlook profile on your pc and find out what changed or the files will end up in two profiles. Depending on how much memory you have left........
Sep 13, 2005 | Palm III
Treo 650 calendar not syncing back to Exchange
I am experiencing the exact same issue. Are you saying that this only occurs with one of your 650s? If so then maybe it is a hardware issue.
Sep 12, 2005 | Palm Treo 650 Handheld
Handspring Treo 180 Handheld Logo
21 people viewed this question
Top Handspring PDAs Experts
yadayada.
yadayada.
fgg3
ray gallant
Are you a Handspring PDA Expert? Answer questions, earn points and help others
