USB PORT TROUBLE
My Windows Vista USB Port wont detect it help
cobalt32@eircom.net
  • 702 Answers
The right driver is important, don' t just rely on the Microsoft driver that might automatically be used. CHeck for a specific driver on the site on the manufacturer.
Jules
Posted on Sep 03, 2008
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
I have loaded USB 2.0 Driver but System could not detect that USB 2.0 Port when I connect USB 2.0 device to all six USB Port. I am having DG31PR Motherboard. I checked in BIOS setup. High speed port enable...
You have not mention what Operating system is on your PC.
For Windows OS XP, you just have to install at least XP Service Pack 2 or higher... and the USB 2.0 ports will function. For Vista & Win 7 OS, the USB 2.0 drivers is in the Operating System when you install Windows.
Hope it helps.
Jul 13, 2011 | Intel DG31PR Motherboard
System is not detecting
To determine if your system is detecting the USB drive or not
Windows XP Right click "My Computer" >> Properties >> Hardware Tab >> Device Manager
Windows Vista/7 Right click "Computer" >> Properties >> Device Manager
If your USB drive is not detected at all either the drive is bad or the usb port is bad, I would try another USB port to rule out the issue being a port
If you see a ? or ! then your operating system had trouble installing a driver for it uninstalling and reinstalling the driver should resolve the issue
Please comment if you need further assistance or clarification
Thanks
If
Nov 21, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
A vista OS is failing to detect lexmark 8300 via USB port When i plug a flash or another usb device on the same port it plays i tried to reinstall the drivers but they cant work. what could be the problem...
ok.....
  • click the start button.
  • type "services.msc" in the run bar.
  • Allow it through UAC.
  • now search for an entry called "print spooler
  • double click it
  • in the startup type type select "automatic".
  • restart system
  • this should fix ur problem.
Jan 13, 2009 | Microsoft Windows Vista Ultimate Edition
How to upgrade to hi-speed USB ports?
you answered it yourself.
"how can i upgrade my motherboard!"
add a pci sub 2 controller.
Nov 29, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Usb port not working
If you have Vista check M/soft site for bulletin 940199
Vista has a habit of losing USB ports and there is a fix for it
Aug 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
ADSL Modem Huawei SmartAX MT841 USB driver not supporting Window Vista Name update of Vista
Hi!
Do not use the usb port or cable. use the RJ 45 port instead. and configure PPPoE and connect using UTP / STP cable with RJ 45 connector straight crimped.
Jul 27, 2008 | Computers & Internet
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
The flash drive purchased doesnot work when pjugged into the usb port on my desk top but it work on my lap top? How do I get it to work on my desk top
Hello claponte
FIRST, THE HARDWARE SIDE:
If you just purchased your flash drive, then it is using the USB 2.0 (high speed) standard. Prior to that were USB version 1.1 and, before that, USB 1.0 standards.
USB 2.0 devices will still work when plugged into USB 1.1 ports - just at a reduced speed)
However, computers w/ USB 1.0 ports cannot properly detect USB 2.0 devices. On those computers, you'd need to install a USB 2.0 expansion card in order to add USB 2.0 functionality to the computer.
SECOND, THE SOFTWARE (DRIVERS) SIDE:
On the software side, USB devices are "plug-and-play" on Windows XP & Vista systems. This means they do not require special drivers or installation for them to work properly. The drivers needed for them to operate are already built into the operating system.
However on operating systems prior to Windows XP (Windows ME, Windows 98SE, Windows 98...) drivers are needed for USB devices to be detected properly.
These are two possible reasons why your flash drives don't work on your desktop computer.
(01) The computer is an older one using USB 1.0 technology
(02) The operating system is pre-Windows XP
Another possibility is (if your computer USB ports are at least 1.1 standard and your operating system is at least Windows XP) there is an issue w/ the USB ports on your desktop computer. This could be a hardware or a software issue still.
Please, let us know if that's the case and we'll help you to trouble-shoot the issue.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Computers & Internet
Sync Manager Problme with Vista with LG CU500
The problem is a driver issue. It is strictly a LG/Verizon problem, and not Windows. What you should is hook up your phone your computer LG USB cable and using the Music Essentials CD-ROM.
Install the latest version of BitPim where  you can find at http://www.bitpim.org/ .
"I hooked up my phone to my computer via the USB cable, and opened BitPim. Much to my dismay, bitpim did not find the COM for the LG Modem".
However, Vista popped up the window in the taskbar telling me that new hardware was detected but could not be installed. I went to Start > Search > Device Manager
Once the Device Manager is opened up, you should see an unknown hardware profile for the USB cable/phone. In my case, Vista seemed to recognize the fact that it was a LG USB Modem, but didn't have the driver. Anyway, right click on the unknown driver and select "update driver software." Surprisingly, Vista will tell you it found a driver. Unfortunately, when when you go to install the driver 2 new unknown drivers will appear.
To fix the 2 unknown drivers, all you have to do is insert the VCAST Music Essentials disk into your disk drive, and point Windows in the direction of the files for the drivers on the VCast Music Essentials CD (in my case, the D: drive).
Windows finished the install, and from their BitPim recognized the cable on COM5.
That should work.
Jan 22, 2008 | Cell Phones
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
