Question about Brother MFC-7820N Printer
Back cover open message
I keep getting a message that says BACK COVER OPEN. PLEASE CLOSE BACK COVER. I have looked all around this printer and I do not see anything open. I have tried everything. Open and closed every compartment I can. I have even shut off the printer waited and turned it back on. Nothing seems to work.
I had the same error message. I also tried every compartment... Here's ultimately what my problem/solution was...
I turned the printer around and fully opened the back cover. I found that one of my kids had somehow fed a small piece of paper/cardboard into the printer. When I opened the back cover all the way I could see that obstruction (which I hadn't seen before). Pulled it out, and the error message went away. Works fine now.
Posted on Oct 09, 2008
This is the most useless response - what switch? which door? what do you mean by "put a piece of paper in" - it's a printer, there is paper all over the place. Can you be more specific, please.
Posted on Oct 04, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
There isa switch that is not being activated, open each door there is a small hole that have a switch , put a pice af paper in and activate the switch
Posted on Sep 02, 2008
Keeps saying cover is open/ please close the ADF cover
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 08, 2016 | Office Equipment & Supplies
My printer is giving message that you rear cover is open for that what to do?
SAMSUNG SCX 4521 PRINTER BACK SIDE COVER IS OPPEN SO PLEASE CLOSE THE BACK REAR COVER & CHECK THE PAPPER JAM IN REAR COVER & AFTER CLOSE THE REARE COVER THEN AFTER SEE THE ERROR YOU CHECK THE BACK COVER SENCER & SENCER PCB
May 01, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to open the rear chute cover.
5. If there is any, pull the jammed paper out of the fuser.
6. Close back cover and put the cartridge toner & drum unit back where it belongs.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
May 20, 2011 | Office Equipment & Supplies
When I change the toner, the LCD shows "back cover is open, please close the back cover" where is the back cover?
The back cover is located on the back of the printer at the bottom. You can find it by looking for two tabs on the right and left that if pushed will allow you to open a paper guide that has two white wheels on it. Open this guide and then close it again so that the system understands that it is closed. That should solve your problem.
Sep 08, 2010 | Brother MFC 7420 All-In-One Laser Printer
Message: Back cover open. Close the back cover.
You might have to turn it off and turn it back on to reset the message. I have a Brother MFC-240C and it does the same thing.
May 30, 2010 | Brother MFC 7420 All-In-One Laser Printer
I open and close the back cover and I still get a error message back cover is open
INTERLOCK SWITCH IS NOT CLOSED LOOK FOR POSITION OF SWITCH AND MAKE SURE THAT IT IS MADE.
Mar 10, 2010 | Brother MFC 7420 All-In-One Laser Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Error mesage
No solution, but I have the same problem. THe printer starts up fine, I hear no grinding noises or other "funny" nioses, and then displays no error message... UNTIL I ask it to print. Then I get a message that says, "Pls (please) Open Cover".
I open the cover and it says "Please Close Cover".
I close the cover and it says, "Please Open Cover"
and this happens forever!
Does anyone have any ideas? Can anyone help me?
Stefan
Mar 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-7820N Printer Logo
537 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
