Question about Konica Minolta DiMAGE Z3 Digital Camera
What is the difference in metering among multi-segment, spot, and center-weighted?
    Master:
  • 425 Answers
Multi-segment metering uses 256 segments to measure luminance and color. This data is combined with distance information to calculate the camera exposure. This advanced metering system will accurate worry-free exposures in almost all situations including backlight condition. Spot metering uses a small circle area within the middle of image to calculate the exposure. The spot allows precise exposure measurements of a particular object without being influenced by extremely bright or dark areas within the scene. Center weighted measures light values over the entire image area with emphasis given in the central region. In backlight condition or when the subject is not in the center of image, exposure compensation will be required.
Posted on Sep 13, 2005
What does the blue light in the corner of the screen mean
Sorry could not find the exact manual. however you can find it from this one as they ought to be similar
http://www.vivitar.com/files_products/1033/ViviCam_F124_Camera_Manual.pdf
It is called the METERING MENU - three modes (Centre; multi and SPOT). you are set for that spot. you can change that. see page 23
The Metering setting will affect how your camera focuses when capturing an image. Depending on your selection, the camera will be more sensitive to focusing on particular areas in the display and adjust the image color and lighting accordingly.
Center - Averages the light metered from the entire frame, but giving greater weight to the subject in the center
Multi - Used in standard conditions the camera divides and adjusts the settings of the image into several zones for light metering such as complex light conditions, position of subject, brightness, background, direct light and scenes
Spot - Meters the area within the spot point frame at the center of the LCD to set the exposure on the subject in the center of the monitor.
1) Press the M (MENU)/SET button to open the menus for the current mode.
2) Press the LEFT or RIGHT direction control buttons to scroll and select the chosen menu.
3) Press the UP or DOWN direction control buttons to scroll through the menu options.
4) Press the M (MENU)/SET button to select the desired option.
5) A selected option icon will appear on the selected item.
6) Press the LEFT or RIGHT button to select the next menu item. 7) Press the MODE button to exit the menu and return to your previous mode. 23
8) An icon reflecting your selection will display on the LCD screen 9) Remember that this setting will be saved by your camera until you manually change the setting or restore the camera?s default factory settings.
Apr 12, 2016 | Vivitar ViviCam 3188 Digital Camera
How to set the clock pioneer dep p4100
Press SOURCE and hold until your head unit turns off. Press MULTI-CONTROL and hold until Clock Set appears in the display. Press MULTI-CONTROL to display the setting mode. Press MULTI-CONTROL to select the segment of the clock display you wish to set. Each time you press MULTI-CONTROL, one segment of the clock display is selected (Hour-Minute) As you select each segment of the clock display, the selected segment blinks. Turn MULTI-CONTROL knob to adjust blinking segment.
Reference page 29 in your instruction manual.
Jan 04, 2010 | Pioneer DEH-P4000UB CD Player
Has the nikon D40 got an auto setting and what is the metering system
The Auto setting is the green camera symbol on the mode dial. On this setting the camera chooses the metering system (and a lot of other things) automatically.
The metering system is the system in the camera that measures the light and determines the proper exposure. The camera basically gives you three choices: Matrix, Center-weighted, and Spot, but as mentioned earlier, in Auto mode the camera chooses for you.
Dec 21, 2009 | Cameras
Hi, My Nikon D80 is now kaing over exposed
This can happen if you have ISO control set to Auto and have spot metering selected, especially if it's set to spot shadow or spot highlight. Over exposure probably means it's set to spot shadow metering.
With spot metering the camera measures exposure from just a very small point in the scene, and so slight camera movements will cause the metering spot to wander onto different exposure settings very easily. If the camera is either set to use restricted apertures or shutter speeds due to program or lens limitations then it will compensate by adjusting the ISO settings instead
Never use auto ISO, just choose what you need for the conditions rather than using the camera's best (& usually poor) guess. Alsonever use spot metering unless you know why you're using it. The default multi-pattern metering is extremely accurate for most situations.
Please check the camera settings based on what I've said, if it fixes your problem then please rate my answer. If not then please add further details of which lenses and camera settings you're using and I'll try to help you further.
Oct 31, 2009 | Cameras
I need to kown how to set my clock from my pionner dehp6800mp
From the manual:
Setting the clock
Use these instructions to set the clock.
1. Use the MULTI-CONTROL to select Clock.
"Clock" appears in the display.
2. Pushing MULTI-CONTROL left or right will select one segment of the clock display.
Hour -- Minute
As you select segments of the clock display the segment selected will blink.
3. Push MULTI-CONTROL up or down the set the clock.
Pushing MULTI-CONTROL up will increase the selected hour or minute.
Pushing MULTI-CONTROL down will decrease the selected hour or minute.
FYI: The "MULTI-CONTROL" button is the center of the volume knob.
Hope this helps you out.
--Matt
Oct 03, 2009 | Pioneer DEH-P6800MP CD Player
What AE system does the DiMAGE E323 employ?
The DiMAGE E323 employs multi-segments (256-segments) metering.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
What types of metering methods are available?
Multi-segment metering (300 segments), Center-weighted metering and Spot metering are selectable. The position of the spot metering area can be specified at the center of the live image or linked to the Flex Focus Point.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
What metering mode does the DiMAGE Z3 employ?
The DiMAGE Z3 employs three types of metering mode: multi-segment (256-segments), spot metering and center-weighted.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Detection range of metering
In Digital ESP metering and Center Weighted Averaging metering, the detection range is EV2 through EV20. In Spot metering it is EV3 through EV17 (50mm F2, equivalent to ISO100).
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Metering modes
There are three metering modes: Digital ESP, Center Weighted Averaging and Spot. DIGITAL ESP - The camera meters and calculates the light levels or light level differences in the center and other areas of the image separately. CENTER WEIGHTED AVERAGING - The metering mode provides the average metering between the subject and the background lighting, placing more weight on the subject at the center. SPOT - The camera meters a very small area around the center of the subject, defined by the spot metering area mark in the viewfinder.
Konica Minolta DiMAGE Z3 Digital Camera Logo
127 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
