Question about Danby Heating & Cooling
I am have a problem or I really donot know what to do with the 2 hole in the back of the unit. I purchase a unit got no manuals or remote.
Taken new cassate type ac model no MCA-24 CR installed it but when its start after 5 minutes it's stop and the run led fashes 6 times with green led of protect and power led
Posted on Sep 02, 2008
Frigidaire model FFRE1033SI window airconditioner tilt problem.
Water going outside is the important part. The hole is not necessarily the drain, the angle at most is an eyesore!
Aug 19, 2017 | Frigidaire Heating & Cooling
Remote works with on and off and volume but stopped all other functions.
1 Remove the batteries form the remote and blow hot air by hair drier about 5 seconds . replace the older/ used batteries with new one of same kind. Does it solve your problem ?
2. Remove the batteries and unscrew the remote and then open the case of remote , clean the PCB's key pad area with soft and dry cloth , put small amount of carbon ink (purchase from electronics parts shop- cost $0.5 approx) on key pad's back side round dots, let it be dry for 30-45 min , assemble the remote and fit batteries and enjoy.
May 27, 2016 | Universal Remote Universal Genesis Remote...
I have a hugh, older model, 2000 Toshiba TV, but I can't find a remote to work it. I have purchased a dozen or better and no good. I have 2 Toshiba TV remote controls. I donot know weather they go with...
If you only want to control the volume and channels, then a "Oneforall" remote will work. If you want to sell the toshiba vc-661T remote, email me. mike49309@hotmail.com
Feb 07, 2011 | Toshiba Televison & Video
I left my lights on and want to know how to bypass security code for my sony xav60. please help if u know.
5415 enter - from the remote...this is the master code for the unit
Fellow Sonay xav-60 user
Jun 02, 2010 | Sony Car Audio & Video
How to connect the amp,too many inputs and outputs
I'll try to help you step by step from your question. My answers will be in all caps. Here we go.
I really hope u can help me,i have 2 basic speakers with connections in the back for the amp leads to go into,but i am really struggling with what wires i put into the amp and in which connections and then really, really struggling with which connections i need to come out of the amp to go to my speakers.
I have a Carlsbro 150w power module
(THIS SOUNDS LIKE A PA AMP AND NOT A CONSUMER STYLE AMP, IS THAT TRUE?)
and it has an Output hole of which im guessing is where the speaker connection goes
(IF IT IS LABELED OUTPUT THEN IT IS INDEED A SPEAKER OUTPUT CONNECTION)
,but on the front of the amp i have 6 channels,each with a hole which is black that says HIGH Z,and also a red hole that says BALANCED LOW Z,
( THESES ARE MICROPHONE AND OR GUITAR INPUT JACKS AND MOST OFTEN YOU WOULD USE THE HIGH Z (meaning impedence) INPUT FOR A MICROPHONE
and next to it i have two buttons with REV and FX
THESE ARE FOR REVERB AND EFFECTS CONTROLS OR INPUTS. YOU DON'T NEED THESE FOR JUST A VERY BASIC SETUP.
.At the other end of the amp ,ive got another red hole that says REMOTE SWITCH
DISREGARD REMOTE CONTROL SWITCH JACK
and 2 black holes that say EFFECTS ,SEND and RETURN.Do i need these?
DISREGARD THESE TOO
I just dont know where to put my output line from my mixer to the amp.
IT WILL GO INTO THE BALANCED LOW Z INPUT, BUT IT MAY ACTUALLY BE TOO HOT A SIGNAL(signal strength too high), LOOK FOR SOMETHING LIKE A TAPE INPUT OR SOMETHING LIKE THAT ON YOUR FRONT PANEL. IF YOU DON'T HAVE ANYTHING LIKE THAT THEN YOU MAY NEED TO USE AN ADAPTER DEVICE THAT WILL KNOCK DOWN YOUR SIGNAL STRENGTH TO THE RIGHT LEVEL FOR A MICROPHONE INPUT AND THEN PLUG IT INTO THE BALANCED LOW Z INPUT.
PLLLLLLLEEEEEEAAAAASSSSSSEEEE HELP.Im tearing my hair out.
HOPE THIS HELPS. GOOD LUCK
Jul 30, 2008 | Audio Players & Recorders
Hitachi onscreen menu access
Afraid only the original remote will fix this. All universals and aftermarket remotes will not have the function you need. try going here www.vancebaldwin.com and use there remote finder and see if they have the one you need
Feb 26, 2008 | Televison & Video
REMOTE CONTROL UNIT DOES NOT WORK
you need to enter the 3 digit code in the manual
hold the set and tv buttons, then enter the code and it should work
Nov 03, 2007 | Samsung TXN2730F 27" TV
Volume resets to 26 every time unit powers on
Jensen Units donot remember your previous setting, its just one of the many reasons not to get one
Mar 27, 2007 | Jensen VM9020TS Car DVD Player
Heating & Cooling Logo
48 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
