Question about Konica Minolta DiMAGE Z3 Digital Camera
What metering mode does the DiMAGE Z3 employ?
    Master:
  • 425 Answers
The DiMAGE Z3 employs three types of metering mode: multi-segment (256-segments), spot metering and center-weighted.
Posted on Sep 13, 2005
Turn on camera and system error screen comes up and you cannot do anything to camera.
1st you need to update the firmware to 1.3u
download firmware here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/index.html (this allows 2GB cards)
instructions are here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/firmware/installation_guide.html
(instructions are a little vague on where macro mode button *flower button* is)
Also, you might have a bad SD memory card. format the card (erasing all data/pics on card)
and take some picks and try again.. if you can
If still a system error try a different SD card to get past error then update firmware with THAT SD card.
IF that don't work.... your hosed... ;(
Nov 17, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
Dimage Z3 System error
plug it in, right click on it in my computer and select format, tick the quick format box and start it up! this will sort it out, i believe the problem is caused by incorrectly disconnecting the camera from a pc/laptop, so when you next disconnect make sure you safely remove it (right click in my computer,select safely remove)
Jul 01, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
Dimage Z3 self-timer
It is in the Drive mode, the options are single shot, continuous, bracket, and self timer. It is not very clear in the manual but it is on the 1st menu page, page 46. Navigate using the arrow button. The default is single shot. When you set the camera to self timer, after taking the shot, it will return to the previous mode, ie. single shot or continuous. If you always use the self timer, you can reprogram the flash mode button to set the drive mode without going to the menu, page 65 of the manual. If you do not have a manual, you can download here : http://ca.konicaminolta.com/support/manuals/digital_cameras/dimage-z/index.html
Apr 23, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Type of flash control
DiMAGE E500 employs Preflash-TTL metering method.
Sep 19, 2005 | Konica Minolta DiMAGE E500 Digital Camera
What AE system does the DiMAGE E323 employ?
The DiMAGE E323 employs multi-segments (256-segments) metering.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
What are the flash metering modes?
The DiMAGE A1 employs three metering modes; ADI (Advanced Distance Integration) flash metering, Preflash-TTL metering and Manual. The ADI flash metering mode combines distance information from the autofocusing system with information from a pre-flash exposure. On the other hand, in Preflash -TTL metering mode, the exposure is calculated with a pre-flash only. Flash emission control is manually selectable in three levels from 1/1, 1/4, 1/8, 1/16. Pre-flash TTL metering must be used when a diffuser is attached to an external flash or a filter to the lens. Attachment of those accessories may cause error in distance information necessary for ADI (Advanced Distance Integration) metering due to reduced entering light. While manual output control is active, pre-flash will not burst.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Is there any difference in the live image between the viewfinder and LCD monitor?
DiMAGE Z3 does not employ the Switch Finder that was employed in the Z2. Frame rate is 50 fps in both models, and smooth real motion monitor can be obtained. Specifications are as follows: Viewfinder : 0.3 inch, approx. 11.8 million pixels LCD monitor : 1.5 inch, approx. 7.8 million pixels
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
What OS does the DiMAGE Z3 support for USB connection?
The DiMAGE Z3 supports Windows98, Windows98SE, Windows Me, Windows2000 Professional, WindowsXP (Home/Professional), MacOS 9.0-9.2.2 and MacOS X (v10.1.3-10.1.5, v10.2.1-10.2.8, v10.3-10.3.3).
Konica Minolta DiMAGE Z3 Digital Camera Logo
54 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
