Question about Cuisinart DCC-1200 Coffee Maker
Will not brew
We follow instructions, lights come on but coffee does not brew. Appliance is warm to touch but no coffee. It was cleaned with vinegar within the last month. Any suggestions?
  • don2853 Jan 30, 2009
    It urns on and will self clean but will not brew
  • 8,596 Answers
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
Vinegar solution cleans mr coffee modelJWX23 but can it be taken apart to clean it better the coffee doesn't come out real fast for long
No. This coffeemaker is not built to be serviceable in that regard.
You can wipe down the inner-sides of the reservoir for a slightly better maintenance cleaning. But, 4 cups of pure white vinegar (no water added) in the hour-long cleaning cycle followed by two pots of fresh water in the brewing cycle is really the best way to clean the rest of the inner-parts which contact the liquids.
If your real purpose for your question is how to resolve the elongated brewing times, I'm afraid that is a symptom of damage to the heating element. This too is not serviceable.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is one, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
You can get a faster brew cycle by putting warm water into the reservoir and making coffee right away. But, depending on your hot water supply, the coffee may not taste quite as good.
Jan 10, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Clean instructions
I presume you are requesting instructions for cleaning this coffeemaker...
With the coffeemaker off (either a red blinking light or no light on), pour four cups of pure white vinegar (no water added) into the reservoir. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Sep 30, 2013 | Mr. Coffee JWX27 12-Cup Coffee Maker
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
!!!!FIXED!!!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
John
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
The light is on to clean it and I do not have an owner's manual. Can you please explain? How do I get the light to stop blinking?
Most coffee makers are cleaned by filling the reservoir with undiluted white vinegar (3 cups). (Do not add coffee.) Remove the water filtration disk if you use it before starting. Then start the brew cycle as if making a cup of coffee (including putting a paper filter or the permanent filter in the filter basket and close the lid). Put a decanter on the warming plate. After brewing, turn off the coffee maker and let stand for 30 minutes. Run another cup of vinegar through the coffee maker. Take the decanter filled with vinegar and discard the liquid (pour down the sink drain). Rinse the decanter. Fill the reservoir with clean water and put in a new paper filter (or clean the permanent filter and put it back). Again do not add coffee. Run a brew cycle to rinse the unit. Discard the water that is in the decanter after the brew cycle. Do a second clean water only brew cycle (with new empty paper filter or permanent filter after cleaning again). However, if you notice an odd taste, repeat the rinse cycle.
You can alternatively use the Mr. Coffee Coffee Maker Cleaner (mix as directed on that package). In either case, this removes mineral deposits (calcium from hard water). For soft water, the cleaning should be done every 80 brew cycles. If you have hard water, do this every 40 cycles.
The manual is available from www.mrcoffee.com/Product.aspx?pid=121 , if I have the correct product version. For some reason this site isn't coming up for me today. Check the manual to find out if there is any specific details for cleaning that aren't shared with other Mr. Coffee products.
I hope this helps.
Oct 29, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
It is stuck on large and does not brew
My keurig did the exact same thing. Stuck on large and wasn't pulling water into coffee maker so it would only dispense a small amt of coffee. I turned it off for about 10 mins. Emptied the reservoir and filled it half way with white vinegar. Ran several cups through and after 2nd brew it ran faster and after the 3rd run with vinegar all the size cup lights came back on. It is working great now. Just empty reservoir with remaining vinegar and rinse. Run a couple cycles of plain water through the coffee maker to rinse out vinegar. I hope this works for you.
Dec 27, 2009 | Keurig B60 Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
HOW DO I CLEAN IT OUT
Every coffee maker I have ever had I have cleaned out with a teaspoon of vinegar to a pint of water run on a full brew cycle followed by a pint of plain water on a full brew cycle.
The vinegar shifts the limescale build up, use a filter to catch and limescale residue.
Jul 29, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
358 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
littlechum55
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
