Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
My camera won't turn on. i've tried switching batteries, but that's not the problem. can you give me an idea of what's wrong?
  • 6 more comments
  • annie1972 Sep 15, 2008
    Exactly the same! Went to turn it on having used it within the past few minutes, thought the battery was dead. Have tried both fully charged batteries to no avail!
  • northernbird Sep 23, 2008
    Same here! Camera completely dead. What's wrong?
  • petrosjon Oct 21, 2008
    I have exactly the same problem. Camera working fine one day and not the next. Have checked CD card insertion as well as trying two different fully charged batteries. Has anybody got any ideas?
  • vlade82 Oct 26, 2008
    Yes i have the same problem, we were using it taking photos at my sons birthday party.At first we thought the memory card was full, so we loaded another card, and now it just won't turn on at all.We tried re-charging the battery, which did'nt help, and came to the conclusion that we need a new battery, until I saw the posting that a new battery didn't help.We thought it had to be the battery as it wasn't holding it's charge, over the last couple of years the charge has been lasting less & less time.
  • Anonymous Nov 20, 2008
    I have exactly the same problem with my canon eos 300d... and no solutions...
  • tedsymonds Jan 19, 2009
    I had the same problem. I looked down the card slot and sure enough at least one pin was bent.
  • Anonymous Feb 04, 2009
    I have the same problem, one day it was working fine went to download more pics and CF card not working. Used another card and still the message says camara not reconised? WHY are we all having problems now?
  • Anonymous Apr 28, 2009
    When i press the on button, it flashes instantly and turns off. I recharged my batteries several times but it makes no difference.
  • 477 Answers
Ok here is the issues with the Canon 300D digital Rebel XT model of camera. First issue bent pins or broken pins the CF card reader on this camera is Surface mounted soildered onto the bottom half of the mainboard a large ammount of disasimboly is required. After removing the mainboard next you need is a desolder rework station. to carefully remove the CF card reader from the mainboard one messup and it might be easier to replace the mainboard. Sometimes. next issue is the power issue if you have no bent pins or missing pins, and the battery door is pushing on the door closure switch and the memory card door is pusting on its door closure switch then most likely you issue is 1 of 3 fuses underneath the power switch. these switches are the size of a few grains of salt very very small.I charge 150.00 to change the fuses and 225.00 to replace the CF card reader as long as none of the traces are damaged. if they are damaged the main board would need to be replaced and it is around 250.00 + depending on the parts cost at the time. If your good at soldering go for it. if not then let the experts do it.
Posted on Jan 22, 2009
 Here is what I have learned after experiencing the same problem.  More likely, it is a problem with the CF card socket (the place where the CF card fits).  Check to see if any of the pins inside (2 rows of them) are bent or broken inside.  This malady can prevent the camera from turning on.  Similarly, it may be that the pins have shorted out. If so, then it is something that would require a trip to the camera repair shop.  I hope this helps!
Posted on Dec 01, 2008
  • 153 Answers
SOURCE: canon rebel xt EOS
Unfortunately it happens on the eos cameras now and again,
see this article, it relates to the 300d but there all fairly similar and the fault occurs on all the eos range..
http://www.michaeljdixon.co.uk/shop/index.php?main_page=page&id=17&chapter=0
Posted on Jun 10, 2008
  • 11967 Answers
SOURCE: I've just bought a new DSLR Olympus camera and
If this is a brand new camera, it's supposed to work with no problems. Take it back.
Posted on Jun 04, 2010
damneddle
  • 1607 Answers
SOURCE: Hi, My batteries died I've replaced them with
Hello.
Here are the things you can try:
Make sure that the batteries are inserted properly, with the + and - in the correct positions. Also, make sure that the battery cover is secured tightly. Check the voltage of new batteries you installed and compare it with the old batteries. Try another set of new batteries.
If that doesn't solve your problem, please update me.
Posted on Jul 27, 2011
darntoothysa
  • 489 Answers
SOURCE: I took a picture with
Its not a problem with the battery, the G7 and the G9 have a problem where a loose screw inside the camera shorts it out and causes it to not power. The repair service is about $85 total for a new part, installation and return shipping of the camera!
Thomas Drayton
Owner www DarnToothySam com
Affordable Digital Camera Repair
Posted on Jul 31, 2011
  • 261 Answers
SOURCE: I have a Sony Cybershot DSC-S500. It won't
hichange battery2 - format the cam by computer3 - check about viruses
Posted on Nov 28, 2011
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
Kenmore Sewing Machine 385.18221
Probably best to take it to a service technician.
Jun 12, 2017 | Kenmore Sewing Machines
I accidentally dropped my samsung S1070 while I was taking a photo, and the lens is now stuck out. It won't turn on, and we've tried replacing the batteries and taking them out. I've also tried...
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Sep 04, 2011 | Samsung S1070 Digital Camera
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
My Kodak EasyShare M320 Digital Camera won't turn on despite it having full battery; I cleared the memory and that hasn't helped. When I press the on/off button, the camera looks like it's...
Check the contacts for the battery. They may be rusted / making poor contact. Did you leave a leaky battery in there for some time?
If you can get an Emory board or small file in there it might help to clean up the contacts. If clean, try bending the clips up to make a stronger contact with the battery.
Oct 25, 2017 | Kodak EasyShare M320 Digital Camera
I took a picture with my Camera shut it off went to go use it again and it won't turn on. I've charged the battery and it still won't work. Any ideas what's going on. Thanks Jamie
Thomas Drayton
May 14, 2011 | Canon PowerShot G7 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
2,240 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
