Question about Canon Office Equipment & Supplies
Our canon d860 will not print. It reads check document open the adf. We have tried that to no avail. It will not copy. I pulled the plug and tried to reset the message, no avail.
    Genius:
  • 2,120 Answers
Look for a switch being held down inside of the document feeder section.
Posted on Sep 03, 2008
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot clear "CHECK DOCUMENT" message on canon PC-D340 printer
Message on the LCD Check printer. I try Press Additional Functions key Press # Press > to #7 Printer Function Press Set Press > to #4 Printer Reset Press Set Press < Unplug printer and repower it. It work`s but only few times, after that the same message. What can i do?
Jun 08, 2010 | Canon PC-D340 All-In-One Laser Printer
Roller marks on copies. I ran the cleaning menu and it asks me to open the ADF to clean the rollers.. How do you do that and where is it.
The adf is the automatic document feeder and its located on top of the machine. use a clothe with 409, simple green or water and look in where you put your copies to be copied. You will see 2 grey rollers. wipe them off. NO alcohol Also are the marks on the docs you are running through the adf or comming out of the copier. Steven 818-888-0006
Apr 26, 2010 | Canon imageCLASS D860 All-In-One Laser...
How I can open "ADF"?
ADF file extension cant be opened by windows you will need a program to open it, you can download a program called winfellow from this link:
copy and paste it into the search bar at the top af your browser.
http://download-free.programas-gratis.net/php/software.php?id_programa=15352&download-Winfellow-Amiga-0.4.4
Also it might be worth getting a registry cleaning tool as adf could be causing registry errors.
Jan 30, 2010 | Canon imageCLASS D860 All-In-One Laser...
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
Every Fax we send has stripes going down it making it hard for the receiver to read our faxes. It doesn't happen when we receive fax, print or make copies.
You say it makes copies without the stripes. Do you use the automatic document feeder (ADF) when you make copies, or open the top and lay the paper on the platen? If you get stripes when using the ADF, the ADF scanner area needs to be cleaned. It's the smaller glass area to the left of the main platen glass. Use a damp cloth and remove any dirt or debris.
Jun 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon PC 1061 ADF Error
Hello, you should open the ADF and try cleaning pick-up rollers + separation pad with alcohol ( some chemicals products works best but i can t remmember what kind of product it is ).
Regards, Mug
Oct 06, 2008 | Canon PC1061 Copier
47 people viewed this question
old marine
old marine
