click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
have you tried this control panel sounds and
connection is good
make sure you have an earth
******** before touching any parts inside your computer
sounds and audio devices select advanced there might be a tick in the mute box
untick it or select audio from the microphone drop down list make sure you
have the right one selected and in the volume box make sure the microphone box
has a tick in it or select the voice tab and make sure that you have the right
media selected also select volume make sure the box for microphone has a tick
in it
hope this helps
