Question about Sony Ericsson W910i Cellular Phone
Battery easily drained
I bought already 3 new batterys but after initial charging of hours, it drained after 10-15 minutes only.???i wonder why?some technician said theres no problem with the phone, it might be the charger>>>????pls help me.tnx alot
    Brigadier General:
  • 7,752 Answers
Try reflashing the phone or also take off the bluetooth if it is on the phone
Posted on Oct 14, 2008
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
I bought a Samsung Monte mobile 3 months ago. Suddenly it has developed problems. The fully charged battery suddenly drains within 2 hours. When I try to access the messages it displays "messages...
just update the software and replace the battery(if its in warrranty period) from ne service centre..
charge the new battery 4 six hrs nd den 4 second time charging let it b empty...do the same for 2-3 charging period den d battery life will b enhanced
Sep 21, 2010 | Cell Phones
This is the second Ni-MH battery I've bought that I've used infrequently over the last year and now it doesn't hold much of a charge after I charge it. Some people say I shouldn't leave it on the charger...
Any battery should start charging for over 8 hours and then it goes down to 4 hours, however no one working on a job wait 4 hours to get the batteries charged so they start cutting time and for that it get less and less charges inside and after a while it refuse to take any charge..Drain your batteries totally, charge them over night, see if that work if not just use them tell you are done with them, and get new equipments not new battery. When buying new equipments and charging them remember never use it until you fully charge it for 8 hours and not even use it for a second before it’s fully charged... Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Drills
Initial charging of my cp's battery
the original battery initial charging is 3 to 4 hours.
but remember before charging the battery it should be already empty for preventing battery damage.
thanks,
Apr 22, 2009 | Cell Phones
Initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Oct 09, 2008 | Sony AA Nimh 2500 Mah Rechargeable Battery
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3
Maybe it's battery. Try to use another maybe helps.
If not it's problem with software in it, what is connected with power point-battery and its showing low battery and switching off.
Second what you can do is to clean connection inside maybe it's stuck something and not giving the power in.
Jun 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Camera Draining Battery
Lachuaeyes,
I have a different model of Olympus and I read that you did not always have this problem and you already have replaced the battery so an old battery is not likely the issue. I suspect you might have something that is draining that was not set in the past. I keep my batteries longer by not using flash most of the time. Is there someone new using the camera that perhaps leaves it on longer than you do after finishing, perhaps uses flash longer? Is there a setting for auto shutdown that has been changed to not turn off as fast as it used to? If none of these I wonder if the flash is requiring more energy than in the past.
Could you tell me if the battery is draining even if you don't use it or is it only if you are using it does it drain faster.
Another possibility is that the charger is not charging so well as it used to but I suspect you leave it in long enough and more.
If you have the ability to check the output voltage of the charger with a multimeter you would be sure it is really putting out enough volts to charge fully.
Please let me know if you have further questions.
HarryF
Dec 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Sony Ericsson W910i Cellular Phone Logo
37 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
