Question about Garden
Roto tiller stopped working
I bought a new briggs and stratton roto tiller. the third time i went to use it there was an oil spot under it. could i have put too much oil in it when i first used it? and what does happen to the machine if there is too much oil in it.
it is a 158 cc front tine tiller 33665.
thank you
I bought three rototillers an every one stopped working after one use an i took it to a dealer an he said it was the coil . why is your coils going bad ?now it wont start needs a new coil agiian i think you should be responsible seeing i bought three it was under warranty but i didnt get it out in time .i like it when it works but if it s gonna do this i wont buy any more of your tools my emalis dugie54 frontiernrt .net i would **** to hear from you ty bob .
Posted on Nov 17, 2008
I bought this tiller off Craig's list. He was up front and told me he had use starting fluid to get it started but that it ran after that. I brought it home started it (via starting fluid) went to the...
your carburetor needs cleaning &,or otherwise before this, try removing the "sediment-bowl" located under the carburetor,needs removal and checking for water and dirt in this bowl and possibly new gasoline in the gas tank, if contaminated with water/dirt after purging all lines after this
Apr 01, 2011 | Briggs & Stratton Garden
I have 2 poulan pro 900 series tillers and they are fairly new anyway when I engage tines they work fine until they hit dirt. then they stop and have a loud clicking noise. I'm sure that they are more than...
If your tiller is one that has power to the wheels and the tines at the same time ... are the wheels going? If it is one with no power to the wheels, are the belts engaging?
Mar 23, 2011 | Poulan Pro PRRT900 17Inch 205cc Briggs...
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
Briggs and stratton model #917388520 6.5hp bought from sears, primer bulb wont push gas into carberator, when it does starts for 5 sec then stops
It sounds like it is getting primed but not getting any fuel after the prime. It sounds like a dirty carb but if it is new that doesn't seem possible. Did it have gas or oil in it when you purchased it. I would return it to Sears if possible as you shouldn't have to deal with this on a new mower. Hope this helps. If not, please provide more info and we'll go from there.
Mar 14, 2010 | Garden
Briggs and stratton platinum 5.5 hp ohv i/c engine
The carby probably has a block either in the idle, jet or float valve. These are both internal to the carby. To fix this, you will need to pull the carby off the engine and get it serviced by a tradesman. If you feel keen, split the carby apart, then run a very small drill bit (.38-.7mm) through the Jets by hand. Also spray carby cleaner in there and blow out with air blower.
Mar 14, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
Briggs & Stratton 3hp engine Flymo won't spark/start
First thing, Have you put in New Petrol? You must.
Then all the basics, Air Filter, Clean Plug, Check a spark is there
Oct 13, 2009 | Garden
I'm looking for the reverse belt routing.
Just take the old belt to a auto parts store and they can match it for you. If you dont have the belt take a piece of twine and put it around the pulleys
to make a template so to speak. Then take that to the auto parts store. Hope this is a FixYa. Pls rate the answer.
Kurt
Mar 21, 2009 | Garden
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Feb 10, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
627 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
