Control board Hi sorry to bother you but could you tell me item # or what i need in the way of a control board ? will try and order thru shopjimmy hey thamks loads Bill
Don't let it confuse you with all the part number mumbo jumbo. Goto ILO, they have a tab for control boards, go there and then look for the part number with your size tv in it. Mine was a 32" and the number 32 was either the first or last number in the part number.
Enjoy!
Willis4play
only 14.95 for the one I needed
this link is for the part for my 32" ILO
http://www.shopjimmy.com/showparts.cfm?item=334904&ps=3349&pn=4
Posted on Sep 02, 2008
Code F- Won't spin
Hi, it means you have an internal short in the display control board. You'll need to order and replace the relay control board in order to correct the issue. This control board is located on the far right corner under the control panel. Below is a link to the control board you'll need to order and replace. Click HERE.....
Mar 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Please tell me current price of MMX310G USB MODEM in INDIA ?
HEY HI BUDDY......
NOT ONLY FOR MODEM,YOU CAN CHECK THE PRICE OF ALL ELECTRONIC ITEMS IN THIS SITE...... http://delhi.quikr.com/micromax-usb-3g-modem-mmx310g-pricelist-all/micromax-usb-3g-modem-mmx310g-pricelist/x27
THAMK YPU...GOOD DAY
Sep 22, 2010 | Cell Phones
Im getting red lines thru the picture that do not go away
Ur controller boards it dead,must replaced all these boards, well solved this problems.All the controller boards it at the bottom of hte tv.Tries Shopjimmy.com,Ebay.com for parts.
Jan 23, 2010 | Toshiba 42HP84 42 in. Plasma HDTV
GA-81915PM manual Problem
Hi
Have you tried to run the scan on crucial.com ?? This will tell you exactly what you need with no room for error - I have used it on note books - laptops and desk tops worked every time - their prices are really good as well
May 03, 2009 | Microsoft Windows XP Media Center Edition...
Water leaking thru motor - being flung by prop
Hi, welcome to FixYa.
By "motor" are you perhaps talking aboout the water pump? it's mounted in the right front of the underside. The "prop" is the coolin fan for the pump motor. On a model GWL11 the part number is a 420324P. it comes as a complete unit. You need to change that pump as soon as possible if it is the source of the leak. If you let that go too long it can actually blow out the machine's main control board.
You can get a replacement here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=216&category_id=46
Feb 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Samsung LNT4042H Audio but no picture...
Hi mgflores84
I have found the inverter at Shopjimmy, I have never recieved a bad board from these folks and they will take them back if they are bad. Here is a link http://www.shopjimmy.com/showparts.cfm?item=030101&ps=301&pn=1  Make sure to compare your board to the one in the picture. Let me know if I can assist further, We can go into chat when you recieve the board and do the install. lone99star
Jan 11, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Oasis washer repair
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Oct 08, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Hey im the guy bout the acer travelmate 230/280 and the USB and PCI was uninstalled or errored...
you are always welcome to post your problem
you can download it from www.soft32.com
Jun 10, 2008 | Acer TravelMate 2303LCi Notebook
I need a replacement part.
Contact the link below. They will guide you to have parts. If the set is obsolete, it will be very difficult to have parts.
http://us.sanyo.com/components/
Jerry G.
May 10, 2008 | Sanyo DP26746 26 in. LCD Television
Frigidaire Front load washer
hmmm...are all the cables re installed in same fashion as before?
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
