Question about Dell W5001C 50 in. Plasma HDTV
Turn off and will not turn on.
It turned off by itself and will not turn back on. their were no exterior factors.
  • akpowers1198 Feb 03, 2009
    Where does one get " rev and firmware updates" for this TV? I've already replaced the power board one other time.
    New Friend:
  • 90 Answers
Power board needs replaced, along with rev and firmware updates.
Posted on Jan 30, 2009
Right blinker not working 1999 Buick park avenue
You'll need to find a wiring diagram an component location chart to check this out . Here is a diagnostic flow chart for trouble shooting this problem ! Do you know how to use a voltmeter ?
DEFINITION: This table diagnoses inoperative turn signals on one side. It assumes that the cornering lamps, hazard lamps, and turn signals on the other side all operate properly.
Did you perform the Exterior Lights System Check?
Go to Step 2 - yes
Go to Exterior Lights System Check - no
  1. Disconnect the turn signal flasher connector.
  2. Turn the ignition switch to the RUN position.
  3. Place the turn signal switch in the appropriate position.
  4. Connect a DMM from the appropriate turn signal flasher connector cavity to ground:
LH: cavity C (ORN)
RH: cavity B (BLK)
Is the voltage within the specified range?
10-15 V
Go to Step 3 yes
Go to Step 5 no
Connect a fused jumper between the appropriate turn signal flasher connector cavities:
LH: cavity C (ORN) to cavity D (YEL)
RH: cavity B (BLK) to cavity F (TAN)
Do the appropriate turn lamps light without flashing?
Go to Step 4 yes
Go to Step 6 no
Replace the turn signal flasher. Refer to Hazard and Turn Signal Flasher Replacement .
Is the repair complete?
5
Repair the open in the appropriate circuit:
LH: CKT 57 (ORN) between S200 and the turn signal flasher
RH: CKT 58 (BLK) between S201 and the turn signal flasher
Refer to Wiring Repairs in Wiring Systems.
6
Repair the open in the appropriate circuit between the turn signal flasher and the IP fuse block:
LH: CKT 685 (YEL)
RH: CKT 686 (TAN)
May 09, 2015 | 1999 Buick Park Avenue Ultra
Turns on and shuts down
It could be several factors. I would start with opening the case side door and blowing out all the dust and making sure the CPU fan is working. If it overheats the PC will turn off to protect itself.
Dec 09, 2013 | Gateway GT5656 Desktop PC
Door handle exterior stays in open pos, door opens turning corners only sometimes. kids ride in the back, please help
The best solution here is to replace the door lock itself as there is a broken spring in the existing lock that is not allowing full operation of the locking mechanism
Sep 28, 2013 | 2001 Chevrolet Suburban
All exterior lights are on when engine is started and wont turn off until engine is off, could it be the switch itself?
Is this happening all the time or just at night? The car is equipped with automatic daytime running lights which automatically turns on the full lighting system at dusk and off at dawn or other lowered daylight situations. Do you have something on the dashboard covering the daytime running light sensor? Is the headlight switch turned to the off position?
Nov 09, 2010 | 1997 Chevrolet Lumina
Screen goes black turns off
You are experiencing RSS (random shutdown syndrome). This seems to often be due to overheating but there are other factors. Read this article http://support.apple.com/kb/HT1237 and see if a firmware update is available for your laptop. This will often cure your very issue.
Aug 27, 2009 | Apple MacBook PC Notebook
How to remove mirror glass 2008 ford f350
here's 2003, don't have 2008
Removal
NOTE: Left-hand dual arm mirror with heat shown, non-heated and aero mirrors similar.
All exterior mirrors
  1. Position the exterior mirror glass in the full down position.
  1. Grasp the top and carefully pull the exterior mirror glass away from the mirror housing.
  1. Disconnect the electrical terminals (if equipped) and remove the exterior mirror glass.
Power exterior mirrors
  1. Remove the jack pins from the exterior mirror glass backing plate.
    • Use pliers to grasp the jack pins at the base to remove.
Installation
  1. Remove the sealing boots from the exterior mirror motor.
  1. Install the jack pins in the sealing boots.
  1. Install the jack pins and sealing boots.
    1. Hold the legs of the jack pins and push the jack pins back into the exterior mirror housing.
    1. Install the sealing boots so the boot shoulder is under the mirror collar and turn each jack pin until the head of the jack pin is aligned with the slots in the sockets on the backing glass plate.
  1. Place the new exterior mirror glass assembly down on a smooth firm surface.
  1. Align the friction pins vertically to the exterior mirror glass backing plate socket and push down to snap the pivot ball into the socket.
  1. s3o~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over heat the exterior mirror glass backing plate. Heat only until backing plate is warm to the touch.
    Using the special tool, warm the main pivot sockets in exterior mirror glass backing plate.
  1. Loosely install the glass.
    1. Connect the electrical wiring to the electrical terminals (if equipped).
    1. Position the friction pins in the mirror housing.
    1. Align the jack pin locating tabs to match with the mirror glass back.
  1. Using a flat hand, press on the center of the mirror glass until seated on the center pivot of the mirror housing.
    • Press the mirror glass toward one of the jack pins until snapped in place.
    • Repeat for second jack pin.
NOTE: If the jack pins do not engage, they may not be aligned correctly. Remove the exterior mirror glass, align the jack pins to the slots in the sockets and repeat the installation procedure.
  1. NOTE: The jack pin should click while manually adjusting the exterior mirror glass.
    Tilt the exterior mirror glass to the full outboard position and then press on the outer side of the class until the in/out jack pin snaps into the socket on the exterior mirror backing plate.
    Tilt the exterior mirror glass to the full down position and then press on the outer side of the class until the up/down jack pin snaps into the socket on the exterior mirror backing plate.
Nov 14, 2008 | 2008 Ford F-350
Intermittent power on/off
My exact same TV did the same thing. Your fuse us going bad. Go buy a new one and replace it.
Jul 01, 2008 | Panasonic CT-32G11 32" TV
Problemin vcr
may be one of these factors, dirt on pinch rollers, tape itself, take up reel,pls chek all these factors and post comments
May 01, 2008 | JVC HRXVC29 DVD Player/VCR
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Dell W5001C 50 in. Plasma HDTV Logo
59 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
