When I plug in the GPS in the car it tells me the battery is low and then it cuts off. I know the outlet works since I use it for my phone and it works. When I plug the GPS in to a house plug it works, just not in the car. Do I need a knew adaptor or plug in thing? Thanks, Chris Walters
I plug in the 12 volt adapter and the unit gives message that battery is low and shuts down. I tried the suggestion to replace the in-line fuse inside the adapter plug, but same message. I have ordered a new car adapter hoping it is a problem in the wire itself. I will revisit after testing new adapter.I plug in the 12 volt adapter and the unit gives message that battery is low and shuts down. I tried the suggestion to replace the in-line fuse inside the adapter plug, but same message. I have ordered a new car adapter hoping it is a problem in the wire itself. I will revisit after testing new adapter.
You can't post conmments that contain an email address.
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
You had your GPS plugged into your vehicle power outlet (AKA cigarette lighter) and you thought you were charging the battery all along. However, your power outlet was not "live" (you checked?) so you replaced the fuse. Your GPS was telling you LOW BATTERY and turned off, and that was why you checked the fuse and it was blown, right?
So now, your power outlet is hot (you checked it right) and you have a good 12 volts DC. You have your GPS plugged in and it still says LOW BATTERY and shuts off. Is there a fuse in the GPS plug? Have you checked for this? Are you able to check the voltage where the cord plugs into the GPS with a volt meter?
There is that possibility that everything is well with your power supply - but you must check and assure you have power. If it is, and your GPS still says LOW BATTERY, I would be inclined to take it for a drive with it plugged in and turned off. At the end of the drive, try it again. (Is your power outlet HOT when the car is not running?) If all is well with the power and you have tried to charge it, the battery may not be accepting the charge due to a battery fault. I don't know if you have the tools required to change the battery or not. If you do and if you can find the battery (there are lots of batteries available at many sites) and it does not cost more than a replacement GPS, I would suggest you give it a try. What the heck, it doesn't work now so you don't have much to loose except the price of the battery.
You might find the battery you reqire at a FixYa.com advertiser to be found here on this page. Your support of FixYa.com advertisers will be appreciated by the site.
If I missed the ball, please provide a little more detail on the matter and I will try again.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Sounds like a bad or low battery. Do you have the Garmin approved charger / car charger?? You may have to send your 265 in for battery replacement or try this: There are three ways to charge the internal battery in your automotive GPS
unit.1
Use the provided vehicle
power cable that came with your GPS unit. The unit will charge while
powered on and using the device as well as when the GPS unit is powered
off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge
in the vehicle, check the fuse in the power cable for the unit and
the power outlet in the vehicle.
Use an AC power
adaptor. Some units come with this power cable to plug the GPS unit
into a wall outlet allowing the GPS unit to take a charge. For units
that do not come with this cable, one can be purchased from Garmin's online store.
For most units, the final way
of charging the battery is to plug the GPS into a powered on computer with
a USB cable2. This
method of charging will be a trickle charge and it may take longer (like a
full day) than the other two options, however it will still charge the
battery. A USB cable is provided with a few GPS models. For those
that don't come with this cable, one can either be ordered from the online
store or you can use a standard USB to mini-USB cable that fits the
unit and plugs into your computer.
1 - Please note
that temperature can play an effect on the charging of a device. If the battery
registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
respectively) then it will not charge. When connected to external power it will
only be operating off of external power. 2 - The Quest® and Quest® 2 will not charge using a
USB cable.
Bad or very low battery Replace at Garmin But first know this:
Normal
0
false
false
false
font-size:10.0pt;
unit.1
Use an AC power
a USB cable2. This
1 - Please note
USB cable.
Normal
0
false
false
false
font-size:10.0pt;
approved charger / car charger?? You may have to send your GPS in for battery
unit.1
Use an AC power
a USB cable2. This
1 - Please note
Normal
0
false
false
false
font-size:10.0pt;
unit.1
Use an AC power
a USB cable2. This
battery. A USB cable is provided with a few GPS models. For those that
1 - Please note
USB cable.
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Disassemble then disconnect speaker/battery connector from printed circuit board. Individually cut the red, green and black wires from the battery. Tape over the wire ends of the connector and battery wires that were cut. Re-assemble and unit will work when plugged into 12Vdc. If you want to use the battery, it must be charged with an external Li-Ion charger using red + and black - for the charging connections to the battery. With the connector to the pc board disconnected, solder and tape the battery wires to the connector wires where cut. Re-assemble and it will work & charge.
